^^^ What he said, It's best way because insurance for younger driver like us (18-25) is bullshit (18 y.o. in stocko brand new corolla = $2,500 a year for car worth 20k), along with stupidly high cost of excess (around $1500 depending on cover), thats means not worth to make a claim if you crash the car like r32 if it's worth 10k, do search, there's information about insurance in this site somewhere that makes good read.
Good tip is get 3rd party (fire and theft) save your hard earned dollars aside for breakages, repairs to the car as it is very common for cars that is aged. At least, it's much better than driving without a insurance.
Best of luck of getting R32 GTS-t I'm sure the turbo power will bring smile to your face everytime you start the engine!
Cheers
Grant
  • Replies 48
1500 excess?!?! well thats the point I needed......seems kinda point less now, because if i crash thats 3400 plus 1500.....nearlly 5 grand.......which in the most realistic case of and accident, would be more then enough to cover the damage
With CTP Third Party Property with Fire And Theft option, would i be facing a larger then normal cost....or are the prices down to earth?
and for that turbo power.....it sure did bring a smile to my face.....which is the reason im upgrading from the VS!
Fire and theft for any car is around 300-500 bucks, doesnt matter if its HSV/Skyline/WRX or whatever. After all your car is only covered for those two things and I think if you also smash into someones house and end up with a million dollar bill, although Id check it out with the insurance comp cos as far as I know there are two types of third party covers.
Yes, there are two types of third party
You've got the one that comes with registration, which is Third Party, which basically means if you smash into someones car, and they get injured and its your fault, it means that the insurance company will cover the cost of the operation, but not the car
The other is Third Party Property, its really just an add-on to the above, so if u wreck there car it'll cover for that as well, and the fire and theft means they'll cover you if your car catchs on fire(if your bad enough to let that happen), or gets stolen it will also cover you to the market value
So no matter what i drive, even if its a turbocharged and supercharged W16 Monster, will not effect the cost of the CTP? if so thats really good news :(
Edited by R32_NthQLD
yeah give em a call or log online justcar.com.au and do an online app for third party and see how much they charge.
The royal automobile club of WA (RAC) were going to charge me $203 for 3rd party on an R32GTS-t and i'm 19, from my searching it's a fairly decent price. Really if your'e wondering how much it's gona cost just spend 20mins n make some calls to insurance co's they will give quotes and a pretty close idea of the costs involved...
Cheers
Edited by WhatBrake
fire and theft prices can vary quite a bit
when i was 18, to insure my stock non turbo TX5 with AAMI third party fire and theft was $450 ish.
with the mods (rims, lowering etc) it had to go through just cars, and they wanted something like $700 for the same cover.
also, its market value up to $5000. not actual market value. and dont go by what you paid...ACTUAL market value is almost certain to be substantially less than what people will pay for a car
yes, the market value is never what the car is really worth,
as for the Royal Automobile club of WA charging 200 something.....i assume this means id have to a member and live in WA? because Just Cars Insurance quoted me for about 450 with Fire and Theft cover.....and tahts a substantially higher price then that of the RACWA, would this be the same for the RACQ?
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
