new skyline
Guest andrewjread
Hi everyone. In about 3-4 weeks I will be the proud new owner of a 93 Skyline gts25t. This car is stock standard.
Just wondering what modifications I should add first. I was thinking exhaust but for a reasonable one it is very costly.
Any mods that I can add that wont break the bank?
ALso, any other general information that a new Skyline owner should know would be great to.
Thanks.
https://www.sau.com.au/forums/topic/9131-new-skyline/
Andrew,
There are lots of cheap mods that can be done, air filter, exhaust etc. But get used to the car first, enjoy it in stock form before modifiying it.
When you get the car then let me know, I may be able to get some rims and tyres for you.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-136807
Welcome! I am sure you will enjoy your new ride.
Wel i think for most of us the 1st mods we do are the exhaust and intake. Exhausts can be expensive but i tend to think that if you get any other mods done you still have a plug stopping it all at the end of your car... get rid of the plug so to speak and you will notice more of a difference with each mod. By the way skyline exhausts sound much nicer than honda civic exhausts.... so i recon go the exhaust and air pod and win up the turbo a little bit... that should put a grin on your face... as far as 17's go... check the for sale section. And local mags stores.
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-136812
It looks like we may be having a cruise on Australia Day, could be a good way to meet everyone and talk about your new car.
Doesn't matter if you don't have the 'line yet, we still allow fags with Supras and Silvias to tag along, haha.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-136824
Guest andrewjread
GTS-t VSPEC... My skyline is getting complied in about 1-2 weeks. This is why I want rims and tyres (low profiles) soon. If I cannot find rims before the car is ready for the PIT inspection I will have to buy tyres for the standard "16 rims. The cheapest I have been quoted is $150-160 per tyre.
I was at Mr Mags the other day and there were a joy set of "17 rims with next to new low profile tyres. They wanted $995 for these but werent sure if they would fit the skyline so I didnt bother. After thinking about this and realising that new tyres for the "16 were going to be $600 anyway, I might as well pay an extra $400 and get 4 sick rims with low profiles. So I went back in there today to arange a deal to buy them with the option of taking them back if they didnt fit. BUT THEY WERE ALREADY SOLD!! ##%@#$.
Anyway, if you know of any deals please let me know as I am looking to buy now.
MrGTST..it is black
Thanks to all...I can see that this forum will be a valuable resource for skyline information.
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-136868
A cruise?
You guys should be drinking and "meating" all the chicks down at the foreshore :alcoholic: :D
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-136872
See'ya:burnout:
Drive past King's Park and I'll lob a brew at ya! :D
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-136873
Originally posted by andrewjread
I will miss my VL though. It has been the most reliable car for the 5 years that Ive had it. Know anyone looking for one? 5spd, bodykit, performance rims, spts steering wheel,exhaust etc.  Bloody great car..........but time for an upgrade.
how much you selling it for?
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-136941
Guest andrewjread
Wheres a good place in Perth to get exhaust work done and what should I get done.
Ive heard that "3 exhaust from turbo back is the way to go but is also bloody expensive from the prices that Ive seen on the net. These were however the "popular" brands.
What sort of exhaust enhancement can I get done that is relatively cheap and will provide a reasonable amount of performance.
Help and advice will be much appreciated!
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-137142
Andrew, You should be able to get a complete custom system for around $1000. I tend to use Genie in Myaree, as they did a good job with mine and do alot of performance work. If you go for name-brand stuff then $2500-$3000 is normal, but I don't think that it is any better than a locally made mandrel bent system.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-137145
rev210,
What exhaust setup have you got? I take it is a complete system.
Andrew,
Many of the exhaust places are crap, you need to find one that does Import stuff often, otherwise you'll get a restrictive exhaust, you want 3" at straight as possible with mandrel bends. Either of the places that rev210 or I suggest will be good.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9131-new-skyline/#findComment-137577
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
