DTEC Boost Controller Pro (DTEC-BC-PRO) The DTEC-BC-PRO is quite simply THE BEST boost controller ever made. It turns your Gameboy Advance SP into a powerful Electronic Boost Controller cabable of controlling boost pressures in excess of 60psi. The DTEC-BC-PRO allows everything from simple "one number" boost control that can be set up in minutes to the most advanced closed loop, gear dependant, RPM, and throttle position based programmable boost controller ever conceived. It comes standard with 60+psi cabaple inline boost control solenoid; 45psi MAP sensor; KnockLite detonation detector and more. Advanced features include the ability to store and switch between five (5) different boost maps; scramble mode; overboost protection; "start boost" feature to speed turbo spool up; and gain control. You even have the option of adding a second solenoid (sold separately) to completely control pressure to both the top and bottom of you external wastegate for the ULTIMATE in high boost control. These are features you will not find in the $1050 Greddy E01; the $1100 Blitz SBC-id; the $750 Apexi AVC-R; or even the $990 HKS EVC V. This incl the DEFI looking Boost guage as shown in the pricture if you have a GBA
The Gameboy Advance SP is not included. While it is required to set up the boost controller you do not have to leave it plugged into the DTEC-BC-Pro.
THESE ARE AVAILABLE NOW. VERY EASY TO TUNE AND SET UP.
LOCATED ON THE CENTRAL COAST NSW
RRp is $635
SAU Price is
$595 till end of Month
Troy
https://www.sau.com.au/forums/topic/91320-avc-rs/
My bad,
These are made by TURBOXS Australia. The come with adaptor to hook upto the Game boy. The Gameboy will show the BOOST GUAGE (DEFI LOOK) Other guages like Temp (oil, Water) and Exhasut Temp etc can also be hooked up...
Troy
https://www.sau.com.au/forums/topic/91320-avc-rs/#findComment-1644862
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
