Yep see Anthony at Autowholesale he'll sort you out for your CPV35 needs... Ive driven the red one - VERY NICE... but its auto :D Good thing with these different to the R34 situation is they are going for pretty much the same at auction whether auto or manual.
If you wanna import yourself - then a basic povo spec CPV35 (coupe), 2003 with higher kms (around 30 - 40,000kms) will set you back around 2 million yen if you can wait for the right price... which landed and complied and in your driveway is around $39,000 !! Not bad considering how much 350Zs still go for and you get the extra 2 kiddy seats :( The "Premium pack" which has BOSE stereo system and usually convertable Sat Nav / DVD and half-leather trim will cost you another few hundred thousand yen (still high kms), right through to a 2005 with 5,000kms or so where you're looking around $52,000 landed or more. But yeah that should at least give you a guide to a reasonable yard price... first lot will probably be stickered at $48k + ... but depending on kms and specification a few thou either side of that would be reasonable Id reckon... but hey - thats just my thinking based on auction prices and "landed quotes" from brokers. In my opinion the extra several thousand yard price for a warranty, after sales support, and BEFORE sales fixing of any surprises is well worth the difference.
Last time I asked, Autowholesale also said they'd be happy to find the right car for serious buyers with a deposit down - so ask where that is at the moment (not really brokering - still pay yard price with warranty and after-sales support etc - but at least get colour and specification level you're happy with).
And just so you know just about everything underbody is interchangeable with 350Z stuff - so you can grab an HKS 350Z exhaust or some coilovers etc and pretty much bolt it right on :D
Interestingly the blue one at Downunder in Leederville is gone - in fact the whole YARD IS GONE! Anyone know if they moved or closed shop??
For anyone thinking 4 door - the model you want to look for is the top of the line V35 350GT-8... 8 speed tiptronic (yes EIGHT speed - world first) VERY TIGHT RATIOS and rapid low end shift changes and PADDLE shift not button shift - same box in the new GTR i read - sposed to be very quick off the mark with the 8 speed and still with the 3.5 litre - pity bout the extra weight of the 4 door though. But these are about 75% the cost of the CPV35 at auction on average - so a nice alternate option with someone with only $34,000 or so to spend.
Edited by Brazen
down under auto has moved to malaga or wangala..not so sure, but if yo go to the website, they have address on it.
the red 35 was driven half years ago on alb hwy, i saw it all the time with dealer number plate on, he should be enjoy that thing very well...
there is one from PMS with 8 speed auto calle GT-8 and it cost under 30k to land with compaliance and ready to rego... a blue one was for sale at 25,990...
they are not that expensive, unless the V35 skyline 2 door. and it looks better than 350Z and perform better...
Do the sums on the V35, search the forums about some of the stock offered in Japan and make sure they can comply the car first as some emission tests are yet to be sourced.
Just because it is offered for sale or you are told the car can be imported it dosent mean you will get it on the road 2 weeks after arriving at the workshop.
Even better let them use it as a test car..............
  • 3 weeks later...
I was going by the name in america. Which ofcourse is G35. I am never wrong so you must get use to it.  :)
If you go by the name in America, then you'd be referring to a lefthand drive example... not the case 'ere then, innit? :P I know you don't probably approve of it, but it's probably best to call it a... oh my gawd... a 'Skyline'...
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
