Well on a GTR you really need to put the sensor after the front pipes join so you get a reading (average) from all 6 cylinders instead of front or rear 3 only.
But for a GTST I can't see why not? Closer to the exhaust ports means a more accurate reading
  • Replies 103
Or you could by two kits from TE and get a reading of the front 3 and the back three, be good to compare anyway
The GTR thing makes sense, but 2 x WBO2 kits is getting a bit exorbinant, my only other issue would be with comparing the accuracy.
It says it's setup to emulate a Bosch LSM-11, what do Skylines run by default, and how close are they to this?
My guess would be there's not much difference, and that it shouldn't effect the car much, but if it did you'd notice the shit fuel economy pretty quick!
  Oosh said:
Looking thru the stats on these, they have an simulated Narrow band outpur (NBsim), is anyone using this?
i.e. Completely replacing the stock O2 sensor with the new WB one, then plumbing the NBsim output in to your ECU, or are you just mounting both?
The recently sold race car (not a Skyline) was done this way, it worked fine. The only problem is you have to leave the unit in the car all the time, if you take it out there is no lambda sensor input to the ECU ie; no closed loop running. I did that for a couple of days without thinking about it, driving around (rally rego) to signwriters etc and it sure guzzled the gas.
While I am tuning the Stagea (for a week or so, in all conditions) I wil run NBsim, remove the standard S&N lambda sensor and replace it with the F&W one. That way I won't have a cable running through the cabin and an expensive lambda sensor hanging out the rear. Asking to be hit or stolen.
: cheers :P
Edited by Sydneykid
Hi SK,
The dicksmiths whisper 2000 is no longer available. But it has been replaced with a better unit: http://www.dse.com.au/cgi-bin/dse.storefro...duct/View/Y1140
My question is how do you modify the microphone so that it somehow detects knock from an engine-mouted clip?
Can someone post up what pinging through one of these chassis ears sounds like?
LM1 vs techedge? WHich one SK do you prefer?
Thanks
  180bfj20det said:
Hi SK,
1. The dicksmiths whisper 2000 is no longer available. But it has been replaced with a better unit: http://www.dse.com.au/cgi-bin/dse.storefro...duct/View/Y1140
2. My question is how do you modify the microphone so that it somehow detects knock from an engine-mouted clip?
3. Can someone post up what pinging through one of these chassis ears sounds like?
4. LM1 vs techedge? WHich one SK do you prefer?
Thanks
Suggestions follow;
1. I haven't seen one of the new style, but I assume it can be modified to suite. All it really needs is a long piece of shielded cable so you can clamp the mike in the engine bay and have the amp and headphones in the cabin. If someone has the complete Autospeed article, maybe they can post it up.
2. The one I saw had no mike mods that I could see, you just clamped it in a convenient place, the standard knock sensor retaining bolts work for me.
3. Sorry, not me, I don't have a portable recorder these days
4. I have used the TechEdge yet, so I can't really say. I chose the Tech Edge this time (over another LM1) mostly for the 1MB logging capacity on board and the number of logging inputs. They are extra cost items on the LM1, plus I like making electronics kits.
:( cheers :)
  PHaT MR30 said:
I have been in contact with tech edge and will be organising a group buy for those interested.
Will get the ball rolling after i get back from Drift Nationals this weekend
any idea on price?
also anyone got a cheap source for a exhaust clamp/venturi pipe?
  NewKleer said:
any idea on price?
Price depends on number of people GENUINELY interested in purchasing
id be interested in one im pretty sure (well i want an afr meter, just not sure which yet)
edit: depends on price....the pre-assembled ones seem to approach the cost of a lm-1 unit after a quick check of the order page
Edited by NewKleer
We will await SK's completion and see how it stacks up against the LM-1.
Oh and the G/B will be something for the new year, im sure not everone has a spare $600 round christmas time.
sorry, left out the word "kit" - im not getting the assembled one.
btw i asked earlier about anyone knowing about price for venturi pipe/exhaust clamp - http://www.rocketindustries.com.au/descrip...p?partno=IM3728 has them for $132 (best ive found so far)
Edited by NewKleer
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
