Hey Sydneykid,
thanks for the reply.
Problem is up here, Toluene is More Expensive than Avgas! I think down there Toluene is real cheap?
so it's cheaper for me to Mix Avgas & 91, which i do quite regularly, usually the last tank of Avgas out of the drum i mix to make it last longer.
toluene is very hard to get as well, the only place i can find it is from a paint manufacturer. i can't even get Methanol, so i use Metholated Spirits in my water injection, Metho is 96% Ethanol.
so i really need to get my engine set up to run on 91, with the water injection.
i have an Apexi FC & Hand Controller with the Apexi Integral boost controller & Sard 700cc injectors, but i haven't fitted them yet. i was going to do that after out last data logging session, but i blew 3rd gear, so that has put me back a bit. currently running a GReaddy Profec B Spec II controller.
here's my mods so you can get an idea;
S/S Extractors
Twin Garrett GT2860R (707160-10)0.6/0.64A/R (450hp models)
HKS Actuators
HKS Dump Pipes
HKS Front Pipe
Cat removed & 3” full back
Splitfire coils
NGK HITOP Iridium Plugs
APEXI FC & Hand Controller (not yet installed)
600x300x125 FMIC (cut the front out to match the IC/8” Ducted air tubes to POD filters)
APEXI POD intake
Modded Intake Plenum
NISMO FUEL PUMP
Nismo Adjustable Fuel Pressure Regulator
SARD 720cc injectors (not yet installed)
Water/Methanol Injection
Wide band A/F meter
HKS Twin Plate Clutch
PAR Racing Products Gear Set, straight cut 1st, 2nd & 3rd Helical 4th & 5th, Beefed up Synchro shift.
Greaddy Prfec B Spec II Boost controller
Apexi RSM Speed Limiter cut & G Sensor
APEXI Coil Over/Adjustable Dampening on all 4 corners
Nismo adjustable suspension/camber
Reply to your random thaughts
1)A/F a bit rich, what tuning - none at the moment, when i install the AFC will start tuning the fuel side. because no Dyno or diagnostic equip in PNG this is why i need to get the LM1 working properly so i'm not flying blind?
2)ECU? std at the moment but AFC to install
3)A/F cruise normally 15:1. what is the Aim Table??
4) closed loop?? what is closed loop
sory i don't follow some of your terminology, i am still learning. (Having fun though)
what do you think of the water/methanol injection?
it seems to work well, i have a digital air temp sender in the last IC bend before the Intake Plenum & can with the water injection i get down to 88Deg Farenheight (32deg C) with an ambient temp of 26 at night.
we get real excited when we get 26 deg ambient temps!! Oh, what i'd give to have a 15deg winders night, it must feel awesome!!
anyway, stuck with what i got & where i am for now!
  • Replies 103
Hey Sydneykid,
S/S Extractors
HKS Actuators
HKS Dump Pipes
HKS Front Pipe
Splitfire coils
APEXI POD intake
NISMO FUEL PUMP
Wide band A/F meter
I would actually go for the Power FC since you need to adjust the ignition timing for the lower ron fuel. The SAFC will cause you no end of grief as it will advance the ignition timing when you are reducing the AFM voltage (that the ECU sees) to lean out the A/F ratios.
The Aim table is the lambda (A/F ratio) that the ECU targets when running closed loop. On a Power FC it is programmable.
Closed loop running is when the ECU uses the standard (slow and narrow) lambda sensor to tell it what fuel to inject to achieve the targeted (via the aim table) lambda (A/F ratio). This is for fuel economy and emissions at idle and cruise, when things happen slowly and predictably.
Yep, toluene costs more than avgas, but at 122 ron you don’t have to use as much to lift the total tank ron to 98. It used to cost us an extra $12.00 a tank to go from 92 ron to 100 ron, so not a big deal really.
:P cheers :D
Edited by Sydneykid
can i just say that is awesome that you have a GTR in PNG. where abouts there are you? A family member of mine does a lot of work in PNG (about 10 trips a year mostly to Port Moresby). It must be a pretty uncommon sight!
:P cheers :D
OK, now i understand the closed loop running uses the Narrow Band stoc O2 sensors to monitor AFR?
so how do you use Open loop? which i assume is utilizing a wide band O2 Sensor, same as is used for my LM1 ARF Meter??
woops i probably used the wrong abreviations, i don't have a SAFC i have an Apexi Power FC ECU & the hand controller. been working on the gear box today, so hope to be up & running, doing more testing this week end. if all goes well might put the FC ECU in & then test some more, then drop the 700cc injectors in.
i wound it up to 1.3bar & did one 1/4 mile run on the Apexi RSM meter, i bogged outa the hole(still getting used to the solid centre twin HKS), then came back wheel spinning & still managed a 12.48 by the Apexi at 180kph, but i also had the laptop hooked up via Datascan sofwear, & the injectors maxed out at 107%, not good!
so looking forward to getting the FC ECU & Hand Controller in so i can adjust. i'll post up the tables when i do some changes & see how it looks?
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
