Im FINALLY HOME!!!!!
had an eventfulday today... drove up to newcastle going 3000rpm in 5th at 100kmh (thanks nissan) and i got off the highway and sumthing wasnt right about my car.... cut a long story short one or two of the coil packs were on their way out...... car still powered and moved so i thought i could get home....(back to syd).....
Anyways left newcastle at about 8 and crusing down the highway.... keeping under 5psi and very little throttle as the car would violently jerk forwards and backwards due to missing and just not accelerating.......
got off at gosford exit (70km after newcastle) to give the car a break..... drove around some quiet streets and the car wasnt performing but thought it would do the job... got back on highway..... car wouldnt even hit 70kmh.... got worse.... 60kmh..... couldnt even overtake a truck up a hill 50kmh... people flashing their lights at me to move.....
1km after i got on i was off the highway...
i thought shit im in the middle of nowhere.... i better get somewhere safe just in case... gosford wasnt far behind so i pretty much followed the signs and ended up on the old pacific highway.... crusing along at 40kmh.... some nice corners down some hills.... get to a uphill the car totally stops..... mid corner.. wont start... nothing
dead...... no lights around
very little mobile reception.....
dont even know where i am.....
10min drive from highway....
this is about where you shit yourself..
through my connections i managed to find my saviour...... his name was Steve........
(free plug)
Steve from A & B Tilt trays was more than happy to come and rescue me..... he started his adventure from the westn subs of sydney and made it to me in a little over an hr (not bad for a 3.5L diesel huh) in the time that i was sitting on the road 2 cars went past... only one stopped....
The lights came out of the darkness and i have never been happier to see a tilt tray loading my car up...........
so after a slow (but continuous) drive back from my broken down spot which was in the middle of nowhere (blocks out images of crime shows where people get killed with broken down cars in the middle of nowhere) we managed to get home..... steves beast of a tilt tray pulled up outside my house and unloaded my car with the woken neighbours looking on.......
My (for now) shitbox resides in its safe place... waiting for me to go and curse at it and then fix it........
why do cars always break down when your in the middle of nowhere.....
so to end this adventure........
id like to say thanks to
STEVEN from A & B Tilt Trays...... 0407 704 203/0423 510 799 (24hr service)
EvilRx from fastfoursforum :O
Because no one else would save my sorry ass except him... and plus he didnt leave my wallet or bank account empty........
Thanks mate........
Ed
p.s. thanks to the unsung heroes that tried helping me over the phone and providing emotional support :)
Edited by Mr Ed32
https://www.sau.com.au/forums/topic/91357-never-been-happier-to-be-home/
lol, sounds like a very eventfull night, lucky you had your mobile phone on you!! otherwise you really would be shitting yourself :O
What would u do, if you were stuck out in the middle of nowhere, pitch black, nobody knew where you were, and you had no way of contacting anybody :S
hahaha the situation was falling apart as it happened....
broke down middle of nowhere...
no cars
no lights
8km to nearest town
decent walk to freeway....
i was so happy to see steve you wouldnt believe.....
time to take her apart now
anyone got any coils for sale?
hey all....
took the coil packs out and sparkies etc etc..... trying to find the problem.....
thought id do some routine checks so i took a fuel line off to check the flow etc......
No flow......
took the pump out (with help of doodz as my onlooker and parts schaffeur) and it wasnt working... gave it a wack with a spanner and it was pissing fuel everywhere...
put it back in the car and it ran for a total of 4 minutes.......
thought stuff it ill get a new one not a 2nd hand one.... 3 days after i got the car in december the pump died... got another pump off a forum member for $50 and it worked up untill now.... (1st one died overnight 2nd one died slowly thats why i didn realise)
called my mechanic.....
Bosch 040 $310 delivered to him within 30 mins.....
made some mods to the fuel system... stuck it in... the car runs perfectly...
still a bump on idle (dont know why!) and a bit of a complain when its still warming up.... but im happy to be driving again.......
Thanks every1..
Ed
its ALWAYS had a slightly lumpy idle..... nothing to do with the fuel pump dieing the other night :angry: dosent bother me really and dosent affect performance.......
when i dont have a big hole in my wallet ill get around to fixing it...
Ed
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
