ohat do you want? Yu need to set a power goal... give some more information to make this a reasonable questions.
To be honest, the fastest on the market on an RB25?
the RB20 NICS turbo, its the smallest thing iver ever seen.
Wont mean you'll make any power though
post more detailed question please
If you want response, just stay with the standard turbo and get a good exhaust system. I have full boost at 2300rpm, and have boost from 1200rpm onwards. It's great to drive like that, but I'd prefer to have something that spooled at double the revs but pushes out twice the power! :O
Mate the stock turbo spools great but because of the ceramic wheel they cannot be boosted hard and they run out of efficency after roughly 1bar anyway. You could put a smaller turbo on and get better response but boost will trail of high in the revs as will power. The stock is good for 200rwkw with supporting mods and anyone who has done this can tell you really notice the difference from stock.
Haha, yeah there pretty tiny. Here's a pic comparing the RB20 NICS and RB25.
why would you want to sacrifice top end?
leave stock turbo,put FMIC and straight though with NO cat not recommended though.or swap your rear turbine housing
my rx7 the thing use to spool up quick but by about 6000rpm the boost/power dropped so it just screamed but couldnt move...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
