Has anyone used this or know of anyone who's used it?
Or any experiences with other Japanese full counter balanced cranks?
For the price id expect it to be pretty special.. any comments appreciated.
I am aware that a 3litre can be built for similar money so lets keep comments on the stroker kits and Jap brand counter balanced cranks!
cheers
https://www.sau.com.au/forums/topic/91381-hks-28l-stroker-kit-in-rb26/
Which stroker kit? The Step I, II, III or high-deck? Each handles more and more power, but the price increases accordingly as well.
They are good up to their rated hp limit, but for the step I and II, I believe you can make something capable of holding the same power levels with less outlay. I dont think the extra 200cc's will make a massive difference in turbo response times etc.
err, then why the f**k would you do it?
Oh thats right, I forgot it came with a counterweight steel crankshaft, forged conrods, forged pistons... now where did I put my $12,000 packet of 200cc shake-and-bake...
I said "massive" difference, it would make a difference but people who go "omg I have an extra 200 corn chips, my turbo will now spool 3000rpm earlier" need their head read.
Edited by Amaru
well lets forget about the price for a moment, i want to hear from anyone whos experienced one. Officially (not counting internet purchases direct from Japan) HKS australia has sold only six 2.8L kits in the whole of Australia. Would love to hear from one of these owners!
i got a JUN 2.7L billet crank and its sooo smooth it looks fake honestly. and it weighs exactly the same as the stock crank.
havent built the motor yet, so no info on usage. 11K rpm should be alright though :(
Xspeed in perth has a 2.8L hks stroker gtr
www.xspeed.com.au
cheers
Brad
Edited by StageZilla
thanks champions! that is a gorgeous looking crank! Im just about to source a 2.8 for myself, but running GT2530's. Where are you located Gav? would be great to see your GTRS results and especially how the motor feels at those high revs.
Edited by SLY33
i dont have a 2.8 crank,just the standard one.
from what i can see the main advantage of a "full counter crank" whether it be forged or billet is you get rid of most of the nasty rb26 destroying harmonics.
so that oil pump can take the extra rpm and not explode.
even beter is if they come with a nice big damper(ati superdamper etc)
the extra 200cc is a nice trade off.
Gav is from perth too but travels 99% of the time from what ive seen :lol:
good to see three of the counterweight crank rb26s are from Perth :angry:
and the JUN crank is rated upto 13K rpm but ive been told to goto 11k to be safe :D
yer i think the main thing with 2.7-2.8 litre RB27-8 is that they really can handle huge rpm 11500-13000 which means even more crazy head work then the motor its self which is why most people are using 3l kits for daily driven cars.
my 2c
Brad
i think japan would get the rb30 blocks if they were soo crash hot and brilliant, but obviously they know they aint very good at high power and thats the reason they have these $20k kits instead which are built for the power from scratch, not from a vl 6 banger family hack engine, which is along way from a rb26 in any stretch of the imagination as being a performance built engine.
compare apples with apples ;)
The Rb26 was built as a high performance motor to start with, so saying rb30's are like a family hack engine, could be the same for rb25's or rb20's.
Im not into the theory of it all, but dont most engine builders strive for what they call a "square" motor? Which the rb30 is ideal..ie 86x86
I think Japan would use them, but like Duncan said they dont have them lying around for $100 a pop....
Guest
    • 90lb/min @ 20psi is wonderful, not so much of a problem with the G35-1050's compressor efficiency (aside from how bad they roll back at higher pressure ratios).  The issue is more to do with the turbine's flow, which is why I'm not sold on going an even higher flowing compressor with the same turbine.  I'd say go back over Motive DVD's testing of the G35 1050 and Hawkins's comments regarding exhaust back pressure issues with it, I'd need to go back but I have in my head he went to the biggest hotside and ended up sacrificing a lot of spool (so it ended up behaving like a bigger turbo) and still had EMAP issues.  I've heard various other experiences along the lines of that. At this stage at least I rate all I've seen about Xonas (for transparency I've not used one directly, but I have spoke plenty with people who have) to have low exhaust restriction for the response they offer for any given setup - basically they allow the engine to breathe, which is good for the engine and makes making power a lot easier.  You arguably don't have to even push quite the same amount of airflow through an engine to make the same power if you don't have the bum plugged up with exhaust gas struggling to escape the engine due to an underflowing turbine.   In terms of reliability, to be fair I've had great luck with Garrett turbos as well - my GT3076R lasted forever, then I sold it and the next owner had no issues, then that car got sold and it was still going strong last I ever heard about it.  The trick is with the old GT-series turbos the compressors etc were no way near as efficient as what we have these days, it was almost hard to push them into severe overspeed situations without having a boost leak or something - and that is what often starts the failure situation.    In terms of your G35 I'm pretty sure you're running yours within sensible limits, something people with Xonas and Precision turbos aren't often so inclined to do.  The "compressor maps" are "Joe blogs ran 45psi through his 6466 so I can do the same" and built their setup to send it to the moon.  I've seen EMAP and compressor speed data where people have actually set that stuff up on Precisions and Xonas which have been run hard and the comp speed numbers are very very exciting at times - like I've seen 76mm Precisions run at rpm that you ideally shouldn't run a G35 1050 lol.   I know people who have run G-series Garretts hard and hard a failure, then replaced them with Pulsar turbos as a cheap "get it going" stop gap with the intent of doing a proper upgrade when THAT fails... and are still running the same thing.   Like anything, ymmv and it's not always to do with the quality or trustworthiness of said product. I've been provided with a bunch of compressor maps for Turbosmart turbos and will update my list based off that, they could prove to interesting reading and an interesting alternative as well.
    • Just cage it, call it a race car, and then fall in love with the chirp chirps through pit area!   Also, this is coming from someone with a completely locked diff...
    • I still have an old R32R left over from when they were a thing in the early 2000's. It was, for its time, done about right. But its time was 20 years ago.  I did try and update it a while back but it was cruelled by a (recommended) muppet of a tuna who couldnt tell his MAP from his TPS. The original spec was: Power FC, 700cc Sards, Nismo pump, 2860-5's, cams (Basically Poncam A's), Z32 AFM's and a half sorted oiling system. Thereabouts 430rwhp irrespective of what was done. So, yeah, very 1990's. I eventually got sick of it not being very refined and bought a Link G4 PNP with some 1000cc Bosch injectors. This was tuned badly and I put the car in the shed for a few years whilst I sulked and went and did other things. Ive come around to the idea of getting it going again so it has a new gearbox installed and some other minor things in the planning. So my questions are, variously (In the context of keeping the Link) What other sensors should I be running eg It has no wideband on it at the moment, nor fuel pressure. $? Is it worth chucking the old ignition system (ignitors etc) for new ignition coils? $2k? Cam/crank angle sensors? Can keep the aircon? $? Anything else? Sorry to launch another what should I do with my car thread but, you know, what should I do with my car? Random photo for historical context.
    • If you think that's harsh, go experience a KAAZ 🥲 Thoughts and prayers for Dose. I had mine modified by a diff shop to make it less brutal, no idea what they did but it's not as brutal as before. The Asian in me was being tight before and went KAAZ instead of a Nismo, lesson learned.
    • From what I understand, the normal Nismo diff is a bit harsh, and the Pro is the one that behaves more nicely, and you only pay Nismo tax twice to get it.
