January - but If Ant hears that my engine won't be together until Feb! (Mods - pls lock ND4SPD out of this thread lol)
very good, you'll have to come for drive down to buno (like if you need an excuse for a drive that is hehehe) should have the new shed up and ready for business(fingers crossed) and the R run in, I dont know if you know but Collie sprint circuit is up and running again with a new surface (surpose to be quiet nice).
pete
how much more lag are we talking. Are the exhurst temps better on the GTRS turbos compaired to the 2530/2560r. would also like to see both of jagr33 dyno runs side by side i was lookn at the t51z.
The T517Z's were an awesome turbo as far as producing power, not too much lag about 4800rpm full boost (1.4bar) in fourth gear. It was the way these turbos hit boost that I was concerned with, especially for a circuit car. I found that boost would build slowly and then all of a sudden it was on, where as I'm assuming the Garrets (being ball bearing) will build boost more linearly. It probably won't push you back in the seat as much as before, but with boost building a little earlier and more linear it would be more suited to the track as the car won't try and spin you around when coming out of a corner coz of the way it hits boost so hard. My car will be on the road in 2 weeks, so I'll post up a graph for comparison.
Cheers
Some people like my old man dont even believe in a run in, the work out medium load on the dyno then straight into power runs, i guess it works cause hasnt blown an engine
sure works, my 25 was done similar to that. like that with a lot of others these days too from what i hear
Hey sydkid greedy make these in an over size kit which i quess is for there 2.7lt kit not sure if it comes with a/c pully as well but may help those people looking to rev past the 9000rpm mark
http://image-cache.skylinesaustralia.com/f...-1130376579.jpg
Brad
Was lucky enough to score a ride in a GTRS equipped GTR the other day. Stock stroke rb26, 260 high lift cams, and with compression ratio slightly lower than std this car makes 380rwkw at 1.3bar. (Motor was still fresh, soon to get tuned with more boost.)
I was extremely impressed and in about 30seconds i was sold on these. i will definitly be getting a pair. Still using dead stock exhaust manifolds (unbridged), the turbo shuffle was extremely minimal, pretty much on par with my 2530's! depending on what gear your in you wouldnt even notice it.
while the dyno sheets may look it, they certainly dont feel laggy, and response felt not far off of my 2530 setup. Full boost at just over 5000rpm, but still pulling nicely from the midrange. And they hit awesomely when full boost arrives, and dont let off till you hit the limiter (8200 in this car)!
i can only imagine that on a higher comp ratio 2.8litre, these turbos will be nothing short of sensational.
I'm glad you are impressed. They are certainly not a popular terb for the "keyboard tuners" but in the real world I was certainly happy with these on my std 2.6.
I'm expecting good things with my 2.8 and higher ratio (gts4) diffs. :P
I have been trying to tell people that for months!!
haha, keyboard tuners :O
yeah mik, well the vast majority of people saying they'd be laggy etc hadnt even tried them! but that was enough to seed doubt in my mind before i actually experienced them for myself!
so thats turbos sorted, now its cams :O
can anyone tell me how much lift affects top end power? are there any rules of thumbs to go by, such as 'x'mm increase in lift will give 'x' kw extra?
at this stage im thinking of something around 270 duration with at least 10+mm lift.
Edited by SLY33
  • 3 weeks later...
the kit has arrived, heres some of the crank. As nice as it is next to the stock crank, still not as impressive as StageZilla's billet item!
HKS forged 2.8 crank as supplied with step 2 kit:
im yet to take pics of the rods and pistons. Rods arent anything special to look at, but pistons look interesting with the black molybdenum coated skirts and gold nickel coated tops.
nice gear mate looks like another pricey build on the way :lol:
so how come the hks crank isnt nice and smooth like the JUN one?
im going 272/11.35mm lift cams but unfortunately i aint run it yet to tell u how it is. thanks to the 22 weeks ive waited for machining of a head and block :P
heres the pics of the surface of my crank...
Edited by StageZilla
yours is machined billet, mine is still a cast crank. the step 3 hks is full billet, but also way more expensive :P For my application the step 2 will be more than enough.
damn the apexi one looks great too!
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
