PALADN Posted October 17, 2005 Share Posted October 17, 2005 (edited) Hey just about to get my r32 back from the turners with around 230rwkw at the wheels but because I use the car for drift I think that Ill need to put a new gearbox in. what I want to know are there any other options other than an rb25 box? will a VL turbo box fit? Before you comment I have done a search & couldnt find the right info Edited October 17, 2005 by PALADN Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/ Share on other sites More sharing options...
R31Nismoid Posted October 17, 2005 Share Posted October 17, 2005 well an MX-7 is older, less smooth (less synchro) and they are the same price as an RB25 box RB25 box or nothing IMO. (and this info can be found ) Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1646274 Share on other sites More sharing options...
PALADN Posted October 17, 2005 Author Share Posted October 17, 2005 hey I found that it was ether the MX-7 box or the RB25 but was just woundering what other possibilities there are Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1646514 Share on other sites More sharing options...
browny Posted October 17, 2005 Share Posted October 17, 2005 (edited) You can fit any gearbox if you have enough time and money.... I'd think RB25 is going to have the best combination of strength, cost & ease of conversion. I've seen another guy convert a GTR box to RWD to save a few bucks, but the comment was something like if you can't do the fabrication work yourself then it's not worth it compared to the RB25 box Edited October 17, 2005 by browny Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1646604 Share on other sites More sharing options...
R31Nismoid Posted October 17, 2005 Share Posted October 17, 2005 Well a GTR/RB25 box are same strength, and the same price. Not worth the farting around even if yo were a bored individual IMO Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1646861 Share on other sites More sharing options...
browny Posted October 17, 2005 Share Posted October 17, 2005 (edited) I thought the gtr box was generally a few hundred cheaper? Otherwise I tend to agree. Edited October 17, 2005 by browny Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1646887 Share on other sites More sharing options...
Sheriff Wan Posted October 17, 2005 Share Posted October 17, 2005 As a rough price how much is a 25 box?? Im in the same boat and just lookin at options. Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1646892 Share on other sites More sharing options...
R31Nismoid Posted October 17, 2005 Share Posted October 17, 2005 i paid $1300, with yoke and a complete driveshaft. i CBF'd shopping around much Box works a treat. A1 condition normally a R box is $1200 anyhow i think Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1646963 Share on other sites More sharing options...
Sheriff Wan Posted October 17, 2005 Share Posted October 17, 2005 Cheers, Thanks for the info Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1647108 Share on other sites More sharing options...
fReak32 Posted October 17, 2005 Share Posted October 17, 2005 use an old pintara box, my mate tried one on his rb25 powered r31 and it lasted a while. i think it was about a week......... lmao Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1647658 Share on other sites More sharing options...
T04GTR Posted October 17, 2005 Share Posted October 17, 2005 (edited) yes a 25box is a good idea. the syncros a only a bit more efective but. if u smash the gears with button clutch it will pop. a good one is the 34gtt box. beter syncro design and uses a bigger clutch.(250mm vs 240mm but pull type) to fit it in the tunnel is a bit of an exercise. is ai origonaly an auto? they have a bigger tunel. getting the corect drivline angle is very important.(getting the back of the box high enough) not somthing that id do in my driveway, but much more thrashproof. mx7 gearbox is the same size but has shit syncros and even worse ratios. unless you want to run 3.4:1 diff ratio Edited October 17, 2005 by T04GTR Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1647664 Share on other sites More sharing options...
R31Nismoid Posted October 17, 2005 Share Posted October 17, 2005 the ratios arent to bad... its just... VL - 1987... R33 - 94-97ish gbox you've got a LOT of time up your sleeve Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1647882 Share on other sites More sharing options...
TurbostyleR Posted October 17, 2005 Share Posted October 17, 2005 or if you dont mind changing gearboxes leave it in there and if/when it does let go just get yourself a CA18DET gearbox and swap the bellhousing as the CA boxes go for 300 bucks or something and arent that brittle... Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1647966 Share on other sites More sharing options...
PALADN Posted October 17, 2005 Author Share Posted October 17, 2005 What about a 300zx turbo box? anyone ever fitted one of them? or know much abouut them Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1648123 Share on other sites More sharing options...
browny Posted October 18, 2005 Share Posted October 18, 2005 I thought these were about the same strength as the RB25 box but just more expensive and harder to find?? Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1648259 Share on other sites More sharing options...
GKTECH Posted October 19, 2005 Share Posted October 19, 2005 I already broke the box on my 32 (with an Rb25) and then found out I had an Rb20 box. Went shopping for an Rb25 box and the cheapest I could find was $1450.. Rb25 boxes are worth a few $$$ Greg Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1652641 Share on other sites More sharing options...
PALADN Posted October 19, 2005 Author Share Posted October 19, 2005 thing is though will the 300zx box? sort of direct with minor mods because I can get them for about 500 each Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1652832 Share on other sites More sharing options...
2LV8ETR Posted January 30, 2006 Share Posted January 30, 2006 I have been told the 300ZX box is exactly the same as the HCR32, except you'll need to change the bell housing. I was told this when doing my conversion but I would want to be sure before purchasing if I was you. I went with the R33 box. Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1908881 Share on other sites More sharing options...
dangerous_daveo Posted January 30, 2006 Share Posted January 30, 2006 Yeah, I dont think a Z32 box will quite work without some stuffing about. Just bite the bullet go the RB25 box. Link to comment https://www.sau.com.au/forums/topic/91391-rb20det-gearbox-possibilities/#findComment-1910530 Share on other sites More sharing options...
