  • Replies 68
Posted Images
Aiiii! She's a beauty :angry:
Got a name for that baby yet?
No mods? You know you wanna do this to her...
http://www.worldcarfans.com/spyphotos.cfm/...oid/6051014.001
Seen here testing at the Nurburgring test track in Germany is a Skyline GT-R test mule wearing a heavily modified body of an Infiniti G35 Coupe. Taking a closer look at these photos you'll notice the slightly more acute roofline, hood air-scoops, widened body with flared fenders, rolled out rear quarter panels and rocket launcher like dual exhaust pipes which is rumored to give way to 480hp from a 3.2 liter twin turbo V6 engine.  Sources say that the purpose of this particular testing session was to evaluate the GT-R's suspension which is being tuned by Lotus at their development center in England.  This GT-R will be exported globally and that includes US (under Infiniti brand) and Australia.  Look for a price tag around $80,000 USD.
Not too sure about the J-Lo sized butt tho...
Edited by Tigger
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
