I need to review the Garrett 28/76 turbo which is going to be fitted to my R33 GTS-T skyline next week.
What are the garrett websites that I can go to, to gain the product information I want to read for this turbo.
Apparently the 28/76 turbo is a bigger turbo then the 30/76 that the other workshop was offering for me but the 28/76 turbo is also cheaper then the 30/76. So this really doesn't make much sense to me. Hence why I want to get some reviews/information on these 2x turbos.
Any help is appreciated.
Thanks!
https://www.sau.com.au/forums/topic/91396-garrett-turbos/
Thanks!
jump onto horsepowerinabox.com
Rall hall also has a website.
The numbers xx/xx really dont mean much at all, i havent even heard of such numbers in sequence.
Get onto thier websites (above) and try to match to what your talking about and then people can help :(
https://www.sau.com.au/forums/topic/91396-garrett-turbos/#findComment-1646835
I take it you are going to use an adaptor to fit it?
Try the turbobygarrett.com site which gives some really good tech specs on their products.
What sort of power (amount, and delivery) are you targetting?
The maximum I'm pretty much aimin for somewhere between now and the time I finish all my mods is around 260rwkw's with a lowmount turbo.
At this stage, I'm keepin with the same manifold as I've been told that I can with these new turbo's on the R33.
Plan next week is to get the new turbo put on as well as all the braided lines getting done, new bosch fuel pump, APEXI AVC-R & labour done. Once all that's in place, I'll be runnin about 10-12PSI on just that. Once I put the intercooler on (which will be at this stage a week after all this is done), I'll be boosting her up to 14PSI.
I've been told that I can go up to 16PSI without any harm, but running on a stock standard manifold, I'm not really that game enough.
https://www.sau.com.au/forums/topic/91396-garrett-turbos/#findComment-1648070
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
