I need to review the Garrett 28/76 turbo which is going to be fitted to my R33 GTS-T skyline next week.
What are the garrett websites that I can go to, to gain the product information I want to read for this turbo.
Apparently the 28/76 turbo is a bigger turbo then the 30/76 that the other workshop was offering for me but the 28/76 turbo is also cheaper then the 30/76. So this really doesn't make much sense to me. Hence why I want to get some reviews/information on these 2x turbos.
Any help is appreciated.
Thanks!
https://www.sau.com.au/forums/topic/91396-garrett-turbos/
Thanks!
jump onto horsepowerinabox.com
Rall hall also has a website.
The numbers xx/xx really dont mean much at all, i havent even heard of such numbers in sequence.
Get onto thier websites (above) and try to match to what your talking about and then people can help :(
https://www.sau.com.au/forums/topic/91396-garrett-turbos/#findComment-1646835
I take it you are going to use an adaptor to fit it?
Try the turbobygarrett.com site which gives some really good tech specs on their products.
What sort of power (amount, and delivery) are you targetting?
The maximum I'm pretty much aimin for somewhere between now and the time I finish all my mods is around 260rwkw's with a lowmount turbo.
At this stage, I'm keepin with the same manifold as I've been told that I can with these new turbo's on the R33.
Plan next week is to get the new turbo put on as well as all the braided lines getting done, new bosch fuel pump, APEXI AVC-R & labour done. Once all that's in place, I'll be runnin about 10-12PSI on just that. Once I put the intercooler on (which will be at this stage a week after all this is done), I'll be boosting her up to 14PSI.
I've been told that I can go up to 16PSI without any harm, but running on a stock standard manifold, I'm not really that game enough.
https://www.sau.com.au/forums/topic/91396-garrett-turbos/#findComment-1648070
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
