The title speaks for itself....
I just so happy that my car is manual... after I went home, give my baby a good wash, then drive around a few times around the suburb.
I still need to find a gearknob as the parts didn't come with knobs. I'm currently using my bro's original Honda Civic knob, which makes it a bit awkward since it's too high for R33.
The only hint left is I still have that Power/Snow button, may
need to take that off and maybe put a rocket style launcher
there for dual stage boost controller.
Also the sweet note of my new trust cat-back exhaust on my car is just brilliant. Not too loud, but could have a slight drone at +/- 2000rpm (cruising 60km/h @ 4th gear). But I found a solution: downshift to 3rd gear gives me more power @ +/-2500rpm and exhaust becomes quieter, no drone...
The new caster rod polyurethane bushes also makes my car handles tighter, I felt safer when taking corners now.
Many thank's to Gerald from ICE Performance for doing all the works on my car. NEXT month: Front pipe (currently on shipment), SAFC tune, and hi flow cat.
Rianto
https://www.sau.com.au/forums/topic/9143-rs73-is-now-manual/
I did the conversion job as well as replacing all engine oils full service and change timing belt. Put on exhaust and replacing caster rod bushes, all up cost me less than $5K, then added GST so it's over $5K. Takes 10 days...
I hope it's pretty ok price as the conversion alone should be around $3.5K already for an R33.... so $1.5K for timing belt, bushes, disc brake machining and brake pad replacements.
But I think I still need to go back, as I just found out when I put my car into reverse, the reverse light didn't turn on, so there must b something they forgot to wire...
At least it's still cheaper than sell then buy a manual, the cheapest changeover price I can get would be at least $8K if I do that, and that's not including timing belt replace/major service anyway...
https://www.sau.com.au/forums/topic/9143-rs73-is-now-manual/#findComment-138162
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
