Hi all just thought I would share my car I have worked on her for a while and I think I'm nearly done with the mods
List so far
TEIN HA S13 suspension all round
Volk EVO's 16x7 front 16x8 rear
Upgraded 4 pot calipers on the front
Upgraded 350Z rear 2 pot disc and Calipers
Front & rear strut towers
FMIC
Blitz BOV
VG30 upgraded turbo
GTR fuel pump
Devorce dump pipe
3" mandel custom exhaust
4" straight through muffler
Oil catch can
AVC-R
Oil press, Boost, A/F ratio, water temp gauges
MONO steering wheel
think thats it
At the drags I have run 14.1 but was running like shit
I mostly use her for drift well what i can anyway
https://www.sau.com.au/forums/topic/91430-my-ceffy/
Their pretty good alot of them don't know alot about performance cars I had one officer ask where the turbos was. that was pretty funny.
I explained to him it was the thing that was glowing.
we do have a Motor vehicle nazi though I havn't been defected in the Ceffy but I used to know someone at the MVR (RTA) and everything was walk in walk out sort of stuff.
most of them just look at major stuff Smoking, tyres, leaking that sort thing.
https://www.sau.com.au/forums/topic/91430-my-ceffy/#findComment-1648666
Yea listed my car at nissan and found out a few things. My car is a factory manual, and it's the top range model with the only one with vented rears that I know of.
I'm a tipical aussie so the gauges I can see over but I had to install a dimmer switch due to it reflecting of the windscreen at night ( hard to see those corners at certain angles :P )
https://www.sau.com.au/forums/topic/91430-my-ceffy/#findComment-1649704
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
    • Just chuck in an ECU, Injectors and a pair of direct fit low mount turbos, that should use to the top of your budget and give it a nice kick along. Also, don't do anything unless you don't need the car daily....if it does blow and you get another 10k bill just to get back to where it is now would you be able to come up with the cash or will it sit for 2 years like most GTRs....
    • Thank you 🙏 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 🫡
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
