at what ohm rating, they are underrated so they are more like 1000wRMS at 1 ohm, and prolly 4-500wRMS at 4ohm and 7-900wRMS at 2ohm ? just guessing but the factory rating is:
4ohm: 400wRMS
2ohm: 700wRMS
1ohm: 800wRMS
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1648873
hi mate!
i wouldn't be too concerned with the "amount" of power the amp has, at this level. you must realise that the difference between 100w and 200w is only 3db. try to use the sub's power "rating" as a guide only because theres not really such a thing as a sub with 200w or 600w. no sub has watts.
oh and don't necessarily buy based on "label". if you had a choice between a 50w orion and a 800w boss, chose the orion, for example.
get your box for the subbie right, invest in some good installation accessories like calbing and mounting hardware etc, have a play around with the sub's position (which way it faces, angle, etc etc) and have some fun!
best of luck
david
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1649926
Thanks for the clarity on that, djhatton. Just found the box, so can now look at the specs.
Kenwood KFC-W3009
-Peak power 800W
-Maximum power 400W
-Rated power (RMS?) 200W
-Weight 4.85kg
-Impedence 4 Ohms
-Frequency response 25~800Hz
-Sensitivity 93 dB/W @ 1m
Now armed with this info, does anyone know what brand/model mono-block amp would be suitable to run this sub to its specifications?
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1651859
still rate the response for power for dollars...
# 12" 4-ohm subwoofer
# pearl mica injection-molded polypropylene woofer cone with urethane foam surround
# overlapping ribs on cone surface for improved rigidity and dampened resonance
# extended pole piece and bumped back plate for increased cone excursion
# power range: 35-400 watts RMS (800 watts peak power)
# frequency range: 25-800 Hz
# sensitivity: 93 dB
# top mount depth: 5-5/16"
# sealed box volume: 1.0 cubic feet
# ported box volume: 1.5 cubic feet
# Recommended Q-Logic Box Type: 1, 2, 3
# warranty: 1 year
found that rating on google for ur sub so theoreticallly the amp and sub are well matched in their ratings 400wRMS at 4 ohms
albeit, you can get an amp that is more powerful than the sub, just dont turn the gain up too high, and vice versa, u can get a amp that is rated less than the sub that is a better quality brand and get a cleaner sound out of it...
depends what you are looking for, take the sub and box to a car audio place maybe and ask to try some amps see if they make a difference?
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1651904
Thank-you very much oRiCLe,that sounds like a great idea. Bought the sub from WOW for $90 (clearance item) and a sony XM-504Z for $230 but it just doesn't seem to want to run sony xs-GS160 splits and the sub to its full potential there-for brisbane car sound suggested a MTX mono-block but still couldn't definately match this up with the sub.
May-be the problem is with the head-unit? Does it really matter if the rear RCA signal is split to run both channels of the amp?
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1652160
splitting the RCA's should work fine, and that amp should be enough power for the splits at least and the sub should work fine with that amount of power, what head unit it it? how have you got the settings on the amp?
Edited by oRiCLe
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1652179
Yeh, your right the amp powers the splits beautifully. head unit is a boss audio BAMP3000. just have the gain set half way on both channels and full pass to the splits, low pass to the sub. Does gain change the frequency of the sound or or change the like 'EQ?'
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1654003
like i said, i wouldn't be too concerned with "matching" your power ratings. that mtx monoblock you were recommended would be just fine :rolleyes:
d
Cool, 'caus it was only a couple of hundred dollars and if it goes that way can hook up the XS-V6935M's that are sitting around to the sony amp. Would this need a battery upgrade?
Cheers again :)
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1654028
the gain chages the voltage sensitivity of the input from the head unit, so by turning the volume of the head unit up as loud as you want it to go, without distortion while the amps gain is turned town to minimum, then turn the gain up on the amp slowly until it is at a desired listening setting, it will give the amp the maximum voltage to the amp...
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1654061
Just an update. If you are splitting the rear RCA between the sub and the speakers, this will have a rather large effect, as you are basically halving the signal that it will recieve. Try changing nothing on the amp, removing the splitter and running the same volume on the hu, you will notice an increase in volume. Does the HU only have 1 RCA output? If it has 2, then run another set of RCAs back to get better performance.
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1654101
Cheers again :rolleyes:
Biggles on this account, couldn't be bothered changing.
You shouldn't need a battery upgrade, as you are not running large amounts of power. If its all in and your headlights are dimming, etc then you'll have to look at those kinda upgrades, but normally you'll be fine.
XM-504Z is your amp. I'd say leave this to speaker duty and get a response monoblock for your sub. I say this because the $ per watt your paying can't really be beaten. Although matching your sub and amp isn't hugely important, there is still a reason they are rated. You will notice a 400wrms amp compared to 100wrms (which is close to what your giving it now). You will get more volume, clearer and drive the amp less which is better for it in the long run, and your giving the voil coils what they are after.
As for the RCA statement above, its true. Give it a try.
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1654119
forget all about power ratings on speakers/drivers. simple as that. like i've said before use them as a guide only.
amp power is a more critical spec and you can NEVER have too much power. don't worry about "frying" your speakers cos you have too big an amp as this is a rare thing (unless you're really careless). the more power you have, the greater the dynamic headroom and the further away you stave off the onset of clipping.
when it comes to setting your system up, remember that gain controls are NOT volume controls. they are sensetivity settings.
read this: CLICK
d
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1654255
Thank you both very much,
Have left the standard battery in and just put in a 40a fuse.
Yeah no the HU only has single pre-outs.
Thanks for the link, djhatton, that was an extremely interesting read and now fully understand what the gain's all about!
Just went and tuned up the sub and the splits accordingly, not to bad at all for now.
Will go and get a better HU in the near future and a monoblock amp as soon as funds prevail.
Thanks for all your time and help,
Chris.
https://www.sau.com.au/forums/topic/91448-mono-block-amps/#findComment-1665849
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
