Found one, 50$ great condition with 70,000km. Thanks Jet!
Cheers for all the offers of clutches with 100,000km+ and 200$  :lol:
so there worth 200+ ? :)
There worth nothing if been on a car with mods
I can get a brand new heavy duty for 300.
