A Question for the more experienced, what pressure should I run front and rear? I currently have the track pressure of 40 rear and 38 front.
I thought I should start around the 26 PSI mark? and go down to 20?
What are your thoughts. I have Toyo T1R's 275/35 x 18.
Thanks in advance
Thanks in advance
Hey Paul, I am running the same size and pattern tyres. I fournd no differecne between about 38psi all round and 30psi all round...you might as well just leave them at 38.
The lower the pressure the more grip the tyres can handle as the tyre flattens itself out more obviously which is tops for those heavy starts :) .. Paul run the pressure that you stated "26psi"
With 275/35 x 18 I wouldn't bother so much about tyre pressures. Maybe drop them to 28-30psi.
You will drop your time more by snapping your gear changes faster :(
Edit: You will find me at the hotdog stand :)
Edited by benm
Yes, The R32 ran a 12.4, it has GTS turbo's. The best I could do was a 12.5. I stuggled to get the power down. I could not get my 60' below 2 sec. I wheel spun using tyre pressures from 40-25psi and did launches at 5, 6 and 7. I did a 7500 prm launch but did not get traction until 3rd gear. My best terminal was 115mph and I got that after having it pop out of first at about 10 ft.
My times were poor, but I had some fun and reside myself and the car to the track.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
