Item: O.S.Giken TS2BD Twin Plate Clutch and Flywheel assembly ( includes Thrust Bearing and Carrier )
Item Condition: Very Good ( Read below )
Reason for Selling: Upgraded ( Read Below )
Price and Payment Conditions: SOLD ( $2,280 total replacement cost new ).
Extra Info: OK Here's the lowdown....
I recently rebuilt a spare gearbox for my car and figured since I'm putting a fresh box in, in should put a fresh clutch in ( thinking the TS2BD would be near dead ). As it turned out, it was in really good condition. But I decided to continue with the new unit so this one's for sale.
The condition of everything is very good ( check out the super-high quality pics :O )
The Clutch plates measured up at 2.7mm & 2.8mm thick ( 4mm thick when new ) so there's a fair bit of life left in this assembly. The mid friction plate measures at 4.45mm.
All that's required of you to install is to cut 2.5mm off your Flywheel to Crankshaft bolts and away you go ( same applies for any O.S. Giken clutch ) !!
This assmebly is rated up to 480hp and will suit HR31 ( R31 GTS-T ), HCR32 ( R32 GTS-T ), ECR33 ( R33 GTS-T ) and will suit a stock BNR32 ( R32 GT-R )89-91 ( push type clutch )
Contact Details: PM me if interested. Sydney sale preferred.
https://www.sau.com.au/forums/topic/91476-o-s-giken-twin-plate/
After talking to a mate last night, he thinks I should be flexible on the price ( which I guess is fair ) so........I've amended the original post to "ono" ;)
So......would there be any interest if I were to put a set of "brand new" clutch plates in and then offer the lot for $1,500 ?? That's essentially a new O S Giken Twin Plate Clutch for $700 cheaper than brand new.
Just to clarify, this sale ( unlike another advertised O S Giken clutch for sale ) is NOT a scam in any way !! Heaps of people have purchased stuff from me and NOT ONE person has ever been unhappy in any way with anything I've ever sold. If the Trader Rating system was still active you would see the proof. :D
got my mech. diff from Scott about a year ago!
Great bloke, if I needed a clutch I'd buy it
Awesome clutch for that price, someone should snap it up no probs
All PM's replied to.
Just to clarify, This WILL go in an R32 GT-R so long as it has a PUSH type clutch and will suit a GT-R that does not have big mods as it's rated to 480hp ( 350kw ) at the engine.
Also, the clutch has had an easy life ( no drags or burouts ) so the metal friction faces are VERY good !! Would take well to a new set of plates.
And yes I will sell / send interstate if no local buyers come up.
Cheers.
what does new plates cost? or re-lineing the old ones?
does it come with flywheel? if so, is it alloy/billet or lightened or anything?
i'm in need of a new clutch sometime soon, my ceramic button one is starting to slip.
any idea on cost of freight to geelong, Victoria?
The clutch comes with EVERYTHING you need to install. All you have to do is cut 3mm off the length of your flywheel bolts ( as is the case for ALL O.S.Giken clutches ) and bolt it all in. The flywheel is just a part of the genuine O.S.Giken kit so I really can't comment on it as a separate component.
A pair of clutch plates ( NEW ) will cost around $850 or $780 for non-spring dampening plates ( makes it a little less streetable to drive with non-sprung plates ).
Shipping to VIC would prol be around the $50 mark ( guessing ).
  • 1 month later...
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
