Hey guys just wanted to see if anyone has had this problem with there cefiros
When i get to 1/4 tank left in my car it starts acting like shit
spluttering, poor acceleration and just generally runs like poo
I fill up the tank and straight away its fine again
was think it could either be
1. Dirty muddy crap in the bottom of fuel tank
2. My fuel pump is spittin the dummy and cant maitain pressure with less than 1/4 tank
3. its just my imagination and its not really happening
let us know what you guys think, or let me know if you have had similar problems
thanks
https://www.sau.com.au/forums/topic/91479-dirty-fueltank/
yeah i think i got the same here - its not the fuel pump (nippon denso 600hp) but when i go around corners on 1/3 tank it does what you have described. i was thinking of a surge tank but i would rather fix the prioblem - could be crap in the bottom.
interested to find out if anyone has fixed this problem
shaun
https://www.sau.com.au/forums/topic/91479-dirty-fueltank/#findComment-1648921
Odds are it is just surging, it may have something to do with the position of the fuel pump inside the tank that is causing "pick up" issues under 1/3 or 1.4 tank.......
Easiest way to fi the problem s to keep it above half :)
My car never see's under half as it starts to surge at about 1/3 (this is whilst on the track drifting though, i don't drive it on the street so i can't comment on that)
PS: I have recently fitted a new tank (clean) and new pump so my surging is not caused by crap in the bottom.
https://www.sau.com.au/forums/topic/91479-dirty-fueltank/#findComment-1652983
Well i got adventurious last night and decided to pop the pump and everything out
low and behold was a fist full of dirt floating in my fuel tank.
Someone obviously didnt like the previous owner in japan
i ended up having to drop the whole tank out and scrub the whole inside of the tank as it was full of mud and rust
it still aint perfect so im going to have to look for a new tank eventually
but for the moment it is alot better and actually runs normally below 1/4 tank
https://www.sau.com.au/forums/topic/91479-dirty-fueltank/#findComment-1660413
I believe the R32 and S13 fuel tanks are the same.......you just need to change the fuel filler neck.
Hope that helps you find one. (make sure you take dimensions etc before you buy to ensure i am correct.......i COULD be wrong, it has been known to happen, sometimes lol)
Thanks for that man
Hopefully the S13 at the wreckers tank is in alright condition
is good to be able to finally drive my car on the limit without it shittin up on me
https://www.sau.com.au/forums/topic/91479-dirty-fueltank/#findComment-1662541
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
