  • Replies 518
Posted Images
ill go if someone wants a passanger, would love to go out tonight :huh:
chintami: dam girl that ride is hot! love the wingless look on your ride.
Yeh ill prob head out tonight...SKYLIVIA where abouts do u need a lift from?
Yeah Sean come out! it's be great to have you there!
I'll be out tonight guy's it's been a while and i miss some of you. (awww)
I've just had my Tattoo coloured in to ^_^
Edited by Veilside R33
Went for a quick drive past the museum last night after catching a movie....no-one there :-( I guess it was half-past 11.
Went for quick drive through Braddon and it was pretty quiet there too(not as quiet as the museum though :-)
