I am slightly concerned...
My car has recently begun blowing the slightest bit of smoke at idle... It looks black... which I spose is better than white..
Also the car doesn't idle very well when warm.. when its cold it has a nice smooth idle, but after it warms up it is constantly hunting.
At around the same time I cut the speed limiter wire (No. 53)
I know that wouldn't have anything to do with it, but I am also thinking maybe the harness isnt plugged back in as tight as it could be??
I will check the harness later, but I thought I'd ask you guys what you think..
https://www.sau.com.au/forums/topic/91500-smoke-and-idle/
There are 2 coolant temp sensors.
One for the dash and one for the ecu.
The one for the ecu controls coolant temp injector enrichment.
Have it reading cool all the time and it will be fine when the motor is cold but bad when the motor is warm. As you said, a little bit of black smoke on idle.
Most likely the afm, but still worth the look if its not.
Edited by Cubes
https://www.sau.com.au/forums/topic/91500-smoke-and-idle/#findComment-1649998
interesting.. I swapped the rhs one on mine a couple of months ago and no diff so I just figured that probably wasn't the problem.. maybe i should investigate too :P
I think I may have narrowed mine to old fuel pump though.. now inplace is a GTR one, problem seems to have gone in 20 mins of testing tonight.
https://www.sau.com.au/forums/topic/91500-smoke-and-idle/#findComment-1650027
its definitely the LHS connector.. you are right... pays to check the service manual :P.. Diagnostics are on page EN-384 of the RB20DET service manual if you have.
If you have a multimeter you can measure whether they are in spec..
I have tried most things but mine has always been a bit over the shop.. seemed better with the pump though (lack of fuel at low revs?). I'm off to clean the *proper* temp sensor right now... see whether that clears it up totally.
https://www.sau.com.au/forums/topic/91500-smoke-and-idle/#findComment-1650062
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
