What do you guys reckon
Is my turbo out of puff or something else not right?
AFR's where 11.5 going to 12.1 up top
HKS GT2510 as far as I know
My tuner reckons that about it for that turbo, I agree. I thought about cams, but he said if the turbo is just too small, it will make the problem worse, as the engine will be more efficient, but the turbo won't be able to keep up
Thanks, Chris
https://www.sau.com.au/forums/topic/91502-2510-on-rb20-out-of-puff/
Yeah, 2510 is the smallest of the HKS range, well it was before they stopped making it!
I want a genuine 220rwkw, as I rekcon that where some good numbers lie both at the drags and around Mallala.
I want a low 13sec car, and something I can lap Mallala in around 1.25
I'd be happy with that. I just want to be able to use the revs, as at the moment it feels like it dies in the ass after about 5500rpm, as you can see on the dyno sheet
What would you want for your turbo? It would be interesting to see what it makes on a RB20!
lol...dunno what its worth, as i bought it with the car when it was freshly highflowed. Its made about 220rwkw with this motor (i reckon it has slightly more due to the air pod shitter im running which will be changed soon)
Ive got pics of the exhaust and compressor side...Shaun and Cubes have seen it too....depends on when i'll be buying the xr6 GT35r for mine as to when ill be taking it off....I'll catch up with you this Sat. at Boostworx and discuss more on it ;)
Chris32
Between 118 and 130kmph your torque band is dead flat but your KW figure goes from 180 to 193. than ofer that it tapers off real quick. so to get the power you want it will need to breethe better up top.
As you are rubnning 1.35 bar the compressor is spinning at its max efficency range at high rpm so the only way to make more power is with better flow.
Considering you prob already have a very free flowing exhaust. 3" turbo back with a good dump pipe and a very high flowing catalitic converter, there are a couple of things you can do.
1. cool the intake charge further. If you dont have one you could make a waterspray kit for your intetrcooler. because at 1.35 bar you can bet your intake temps could benifit from further cooling help. this will make intake air denser, and make more power. on my car it made 13RWKW difference. ;)
2. you also need to make it easier for the turbo to ram that air in!!! ruling out headwork as its too expensive your only other option will be cams.
350nm is very good torque for the ol RB20 and without better flow you won't usually get any more than that.
also your boost curve is fantastic and i bet your car is very fast on the street and thru the windy stuff.
I think if you can get 220rwkw with that turbo you will have a very fast car. but the odds are stacked against you :)
Boost does nose over after peak power, down to about 16psi
Exhaust is no restriction, 3.5" dump, no mufflers or cat execpt for the rear can
I think air out is the main issue, exhaust housing causing restriction
Its only rated at 300PS!
Getting re-tuned tomorrow, as that tune is quite lean. Going for more timing and fuel. I want to see at least 200rwkw, maybe a bit more if possible
Might try it at 1.2bar and see if that helps with a bit of top end. The mid-range on the road is lots of fun though
Quite a few people keen on my turbo! Lots of PM's!
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
