Excellent!
Just what I wanted to see! As mine is tapering off (140ish), yours is still going up. My turbo is smaller, as it makes a bit more down low and earlier, but yours pulls away up top
Does your car still feel like its pulling hard right up to 7500rpm?
Yeah, I want to just pick up the last 2500rpm on mine thats all so a slightly larger turbo might be the way to do it
Rememeber, Japs use differant fuel to us, fair bit higher octane, so I'm sure if your car was running 101 or 103 RON fuel (whatever they use) you could get to 220rwkw at 14psi just by adding more timing
I'd be running it at least 20psi if I had a 2530, it would come on nice and quick, and be able to hold a decent amount of boost up top
If you look in the 260rwkws thread there is R31 POWER's plot and jnr32r's using 2535.
If you want more power with better response i dotn think you can get away with not having a good manifold. My setup seems to match the 2535s in response and makes more power....and the thing is plain bearing. You would have to think that the manifold helps out of sight as (LOL) most ppl you talk to tell you Trust turbos suck?!?!?!?!
Hey chris.I have 200+rwkw on about 16-17psi.It's a safe tune and not a power one.It feels good on the street with 16psi coming on at 3400-3500rpm and hard at 4000rpm.It holds 17psi and even more to redline hehe.
My boost curve is weird on the dyno graph and i don't know why but it seems fine on the road.
I might get another tune and hopefully see 220rwkw on 20psi.
Last nights tuning went quite well
got the response back it was lacking after last weeks tuning
We adjusted the acuator on the turbo to try and bring it on faster and hold boost up top
It worked quite well, I photoshoped my last dyno as best I could (forgot to get print-out, as it was almost 7.40 and Shaun wanted to go home!)
Picked up about 40rwkw at 100km/h and a fair whack of torque to boot
Feels quite quick on the road now, lots of response!
Still need a bigger turbo, I'd swap all that mid-range for some top end! Would make a crazy drift setup now, comes on quite hard
With the acuator adjsuted, boost was a bit spiky, saw 1.7bar in 3rd this morning, so I had to adjust it down a little, as it was a bit erractic between 2nd, 3rd and 4th. Did get compressor surge at this boost, so it must be at its limit at 1.3/1.4 bar
Not bad for a 300PS rated turbo!
The dyno reminded me allot of a RB25 power curve
This dyno attached is approx what was achieved last night, when I get the printout, I will scan it and post it up
Chris
It does have a adjustable acuator, but the thread was a little rusted and the nut was pretty locked
Shaun just ended up using a pry bar and gave the plate which holds the acuator a bit of a tweak to pre-load the spring a bit more
It didn't need much to get that result. Comes on pretty hard now
Yeah, agree, a good manifold would help if you are running a bigger turbo. 2510/2530 seem to run pretty good with the stock manifold, I think a 2535 would benefit from a decent exhaust manifold. 2530 i'm not so sure, it might bring it on sooner, but I reckon it would then struggle up top
I'm going to video my handcontroller to work out how quick it comes on, when driving its hard to see it all and concentrate on driving
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
    • Good to see you followed your heart, got your dream car and have it pretty well sorted out now. I think anyone can get caught out with a seller not being 100% honest about a cars problems. Can relate to all the electrical issues, had similar issues with my first car (mk2 escort) ages ago
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
