i would also like to see some proven results, we all just asume that the more we spend the better the results are going to be?
ive just fitted HKS 25/30's and fitted R33 GTR dumps as they are a bit larger than the R32 GTR ones (look a bit resrictive).
  • Replies 124
Posted Images
I would recommend the trust MX dump pipe and front pipe kit. It will cost around $1400, But it is the best design I have seen. The dump pipes are split and about twice the length of HKS ect with a shorter front pipe. These are the ducks nuts.
The Trust MX pipe is a regular aftermarket front pipe (~$500). You talking about the Trust/Greddy Front Extension Pipes.
What about these X-force dump pipes to suit a 32/33 GTR.
They are only $499 for the pair through JustJap.com
They are just HKS knockoffs. The split is too short.
the trust and ces long-wastegate style dumps are the only ones of that type I've seen. ces do little things like put a reverse trumpet shaped taper on the turbo outlet flange that increases in size up to the engine pipe diam.
for the money a set of HPC coated comp style dumps would be my preference. if you're going to spend $1500 ballpark it's worth going a bit further to get the 'finer' details.
if Trevor does the test on the weekend i'm happy to organise a group buy, he's done them before but i'll have to get some idea of who'd be interested. the last group buy through advan for the trust models @ $1100 fell over due to lack of interest.
The only thing I would change if I was doing it again would be to use forged rods and stronger head bolts. These items will limit me to around the 350awkw mark – which was kind of easy to get to by the way.
yopu can push it too 400rwkw safely on stock rods with upgraded bolts.
many doing it
and this is where the $ really tell, because you won't get a set of these suckers for under about $1500. so we're back to square 1 ie yes it's better but how much/is it worth it.
my trust "front extension" split dumps or whatever they are called...
were under $1000 (not inclu postage) which isnt that much ontop... had it not been for a certiain moron not sending my parts as i asked i'd have not even needed to pay Import duties, which makes them very reasonable for the price and what you are getting.
Here is a pic of em... very farken nice
http://i7.photobucket.com/albums/y257/ido09s/55927fba.jpg
they look good nismoid. couple of questions:
1 where from?
2 how much all up?
3 does the front pipe section have a flex pipe?
4 how big is the merged pipe? 3 inch, 3.5 inch?
Thanks mate.
thats not my pic lol, i stole it :)
mine are still in customs.
From nengun $950 approx, not inclu delivery as i got a lot of other things at the same time.. so probably just break the $1000
no flex
Where the two come together asfter the splits... i think its 3"
but im just gonna not be using that i dont think... going a twin system from the dumps
1 where from?
2 how much all up?
Thanks mate.
Trust you say :D
i had them first you bastards!! :)
Yep, good point the Nengun option is always worth considering.
I thought the trust pipes had no flex but i've seen photos of something similar, like those posted by Ronin, that has a flex joint. are they copies or have trust changed the design?
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
