  • Replies 124
Posted Images
whats the inner diameter of the tomei dumps??
i've just bought some from the states for around 840 delivered, (fairly good price these days)
i have a large lightweight titanium front pipe here which is around inner diameter of 70mm
hopefully they will be a good match
Thats an excellent price for Tomei Dumps Andrew, good work ;)
I flipped through my version of Hyper Rev (vol 132 from 2008), all the front pipes have 70mm inlets, the only one bigger was the "Midori" front pipe with 80mm inlets and 90mm outlet
Tomei gtr dumps are 76.3mm
Is that tomei's quoted size? or an actual internal measurment? the reason i ask is they often do the Od, and not the Id..
as i said my internal on the front pipes are are 70mm exact. so i pray tomei's are Od so it will be similar :P
the internal diameter outlet on the front pipe is around 88mm tho.
Thats an excellent price for Tomei Dumps Andrew, good work :blink:
Thanks
http://www.edoperformance.com/ is the place to go :blink: they were listed on tomei's website as a distributor in the states. and were very well priced, should have confirmation today of them posted
Edited by Angus Smart
I too, am dealing with the headaches of dumps pipes as well...
When my engine was built (-5s) i put on the JJR pipes. Although I vented the gates to atmo. Had a full 3inch and made 326 on 18psi for run in, no worries. No creep etc etc.
Then i went to the HKS Dual Racing. Thats the only thing I changed. Full twin 65mm zorst. I get BAD creep up top, 23,24,25++ psi because the zorst flows alot better than what I had. So theres proof theres a problem in the design of the dump pipe flange, where it bolts to the turbo; nothing to do with turbulence of the gate pipe going back into the main.
Id love to get tomeis cos theyre pretty easy to come by but at 76mm its going backwards. And its not a case of finding the right front pipe for them obviously.
HPI bellmouths are 65mm but 900 odd dollars from JJ.
Any suggestions?
try yahoo auctions thru import monster, there was HPI bell mouth that sold recently.. i picked up genuine hks split dump kit (new) for $500 few days ago on ebay.. got tired for looking for tomei or other good jap bell mouth
Edited by BWRGTR
anyone know inner diameter to genuine hks dumps (split type) on the side that connects to the front pipe..
They're not very big, 55mm ID. I have some custom dumps that RIPS made me a few years ago and they're 60mm ID. Tomeis are the way to go.
  • 9 months later...
2860-5's.
Will use standard manifolds with flanges ported. Car already runs power FC, 550cc injectors and blitz boost controller.
Turbo's upgrade will include fitment of decent fuel pump & adjustable cam gears (still debating whether or not to install poncams).
If I don't find R34 GTR dumps then I will buy the tomei ones. I really like the CES race pipes but I was quoted around $1600 (not including ceramic coating).
Being a standard R32 engine I only want to run around 1.2 bar and would like around 300rwkw for now. Motor is pretty healthy and has low k's for age (136,000).
Yeah they may be a bit too big initially but I wouldn't mind rebuilding the engine in a year or so. The car doesn't even see 2000km a year so they should still be in good condition when I do decide have the engine rebuilt, so I figured to just buy them now.
So the R33 GTR and R34 GTR dump pipes are the same size? And are good for decent power?
The Tomei website lists the BNR32/33 stock dump pipes as 58mm, and BNR34 as 55mm: http://www.tomeiusa.com/recentmail.asp?mid=106
Confuses the subject alittle, as I assumed the stock R32 dump pipes were 50mm because that's what the stock front pipes inlet's (internal diameter) i measured were.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
    • @PranK, why do we have this restriction? Because photos are the first thing that gets asked of new people on the forums. Do the spam bots post photos if allowed?
    • How do you rate the clutch @joshuaho96? Sometimes I wonder whether it's genuinely very driveable or whether I just feel that way because it cost a good chunk of money. Most recently when seeing the guy at the tyre shop struggle to move the car...
