i would also like to see some proven results, we all just asume that the more we spend the better the results are going to be?
ive just fitted HKS 25/30's and fitted R33 GTR dumps as they are a bit larger than the R32 GTR ones (look a bit resrictive).
  • Replies 124
Posted Images
I would recommend the trust MX dump pipe and front pipe kit. It will cost around $1400, But it is the best design I have seen. The dump pipes are split and about twice the length of HKS ect with a shorter front pipe. These are the ducks nuts.
The Trust MX pipe is a regular aftermarket front pipe (~$500). You talking about the Trust/Greddy Front Extension Pipes.
What about these X-force dump pipes to suit a 32/33 GTR.
They are only $499 for the pair through JustJap.com
They are just HKS knockoffs. The split is too short.
the trust and ces long-wastegate style dumps are the only ones of that type I've seen. ces do little things like put a reverse trumpet shaped taper on the turbo outlet flange that increases in size up to the engine pipe diam.
for the money a set of HPC coated comp style dumps would be my preference. if you're going to spend $1500 ballpark it's worth going a bit further to get the 'finer' details.
if Trevor does the test on the weekend i'm happy to organise a group buy, he's done them before but i'll have to get some idea of who'd be interested. the last group buy through advan for the trust models @ $1100 fell over due to lack of interest.
The only thing I would change if I was doing it again would be to use forged rods and stronger head bolts. These items will limit me to around the 350awkw mark – which was kind of easy to get to by the way.
yopu can push it too 400rwkw safely on stock rods with upgraded bolts.
many doing it
and this is where the $ really tell, because you won't get a set of these suckers for under about $1500. so we're back to square 1 ie yes it's better but how much/is it worth it.
my trust "front extension" split dumps or whatever they are called...
were under $1000 (not inclu postage) which isnt that much ontop... had it not been for a certiain moron not sending my parts as i asked i'd have not even needed to pay Import duties, which makes them very reasonable for the price and what you are getting.
Here is a pic of em... very farken nice
http://i7.photobucket.com/albums/y257/ido09s/55927fba.jpg
they look good nismoid. couple of questions:
1 where from?
2 how much all up?
3 does the front pipe section have a flex pipe?
4 how big is the merged pipe? 3 inch, 3.5 inch?
Thanks mate.
thats not my pic lol, i stole it :)
mine are still in customs.
From nengun $950 approx, not inclu delivery as i got a lot of other things at the same time.. so probably just break the $1000
no flex
Where the two come together asfter the splits... i think its 3"
but im just gonna not be using that i dont think... going a twin system from the dumps
1 where from?
2 how much all up?
Thanks mate.
Trust you say :D
i had them first you bastards!! :)
Yep, good point the Nengun option is always worth considering.
I thought the trust pipes had no flex but i've seen photos of something similar, like those posted by Ronin, that has a flex joint. are they copies or have trust changed the design?
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
