i wish i went with normal dumps like tomei or something single and large,
i'm using the trust split front/dump in one its rather large and kind of heavy.
i would kind of agree that split dumps were a fad? they might work, but when at full throttle, and max boost the gate is open to regulate the boost.. perhaps thats where the turbulence happens
  • Replies 124
Posted Images
I just picked up a set of Tomei dumps and wondering what front pipe people are using with its very largish diameter (76.3mm according to Tomei)? I've been looking at many jap brand websites to see what could mate up and most seem to offer 70mm. I'm just thinking of the flow effects if there is a "lip" because of the smaller diameter fronts.
I would get some custom made using 3" (76.2mm) pipe/tube, best way to go. Then you can get the exhaust place to merge them to what ever diameter and flange type you want to match your existing exhaust (or get them to make the rest of it to the back of the car).
And yes, doing it this way you well prevent any flow restrictions associated with a square edged "lip".
the largest I've been able to get are the HKS front pipes (don't buy secnd hand ones though as they updated their design a year or so ago). They are just over 70mm twin pipe into 85mm single. most GTR front pipes are 60 or 65mm twins into 70 or 80mm single. plus the HKS pipes are welded to the flanges on the inside of the pipes which gives no lip and a nice smooth transition from flange into pipe, good for flow. they are the best match I've found for the tomei dumps.
  • 3 months later...
Any experience with the autobahn88 rb26dett dump pipes?
Here's a pic of them:
http://www.performance-wise.net/USERIMAGES...20OUTLET%20.JPG
Also are they the same as the JJR stainless dumps:
http://justjap.com/store/images/P/jjrdumpkitrb26.jpg
China crap is poorly welded, flanges often overlap causing restriction and due to taking little time to check angles on the welds means you may find that bolts or studs will not be able to be fully done up without machining off over weld.
JJR and I dare say Autobarn888, the later I would run a mile from in a big hurry.
I've seen 6 too many of these dumps and had to mahine everyone of them, a couple bolted up but, the overlap on flanges and weld protusions meant that if you did just bolt them up they would more restrictive than stock.
Get something custom made or buy something decent. getting the SOB's on and off isn't worth the small saving for buying a peie of crap.
The stock units can be used but, they are very poor flowing compared to an good set of aftermarket units. The stock ones are often poorly cast matched and the only set I ever retained I spent time with a die grinder on. Without a doubt some Tomei's would easily outflow them.
What about X-Force dump pipes? http://justjap.com/store/product.php?produ...=276&page=1 alternate picture: http://www.xforce.com.au/img/products/p25_01.jpg
I don't know much about X-Force, but at as a closer look they look the same as the Autobahn88 dumps.
Edited by Moodles2
re-read the post above yours...
all of those little short, split GTR dumps are a poor compromise. they have a tiny wastegate pipe, and a tiny main pipe too, and end up merging into a single 60mm pipe. and when poorly made are even worse. even the genuine hks ones that everyone copied are pretty average. i wouldn't use them, much less the copies.
so it doesn't matter whether autobarn88, jjr, xforce, china star or whatever you call them, they are all cheap for a reason. they are cheap. and they were all copied off a flawed design to begin with.
the dumps to go for are the tomei ones. this is what GOOD GTR dump pipes look like. if you can find some like this, that are good qual, and not tomei, then grab them. otherwise just stick with stock, or hold out for the tomei ones. they are worth the money.
My question was really aimed at the company itself, do X-Force just make chinese quality knockoffs made here in australia?
:domokun: fair enough. well I can't really comment on x-force quality but as far as I know they are just another company putting their name on chinese generic products (could be wrong though). the fact that their dumps look the same as all the other HKS copies tells you most of what you need to know. my advice is avoid ANY brand of HKS copy dump.
Are the Tomei dumps superior to the HPI and Power Enterprise dumps (apart from HKS and Tomei, HPI and Power Enterprise being the only other dumps available, except for the Mines And Nismo dumps which are 1.5k+):
HPI (3/4 the price of the Tomei dumps on nengun):
Power Enterprise (the same price as the Tomei dumps on nengun):
Surely someone must be able to produce something like that here for a decent price, make a jig and produce, if they do then I will be in for a set, I am about to change turbos and dont really have 1k to drop on some dumps, was going to go some xforce, or something but after reading some comments I have been turned off, I had a set which I bought off this form but never arrived (was so stoked about thet $300 down the drain). Anyway hope something comes soon.
I think I'll go with the Greddy/Trust extension pipe, front pipe+dump pipe in one: http://www.trust-power.com/02turbo/extention_fp.html Unless I can still source a 2nd hand front pipe in good nick, and pair them up to the HPI dumps I linked
  • 3 weeks later...
just looking into these adaptors
Richard: the pipes are designed to take the R33/34 GT-R sensors, but Trust includes a little adapter that screws in to the hole and reduces the size so you can fit the R32 variety (
any one know where to go to get them?
anyone know inner diameter to genuine hks dumps (split type) on the side that connects to the front pipe.. being hks im hoping it wont have any probs being used with hks gt-ss turbos
on another note, here's a pic of tomei vs stock 32 dumps
whats the inner diameter of the tomei dumps??
i've just bought some from the states for around 840 delivered, (fairly good price these days)
i have a large lightweight titanium front pipe here which is around inner diameter of 70mm
hopefully they will be a good match
    • I did a bit of googling, the color MCM used was Galaxy Grey from House of Kolor. This is actually a colour I picked out about ~10+ years ago (or more). This one is a stock BMW colour, I guess over the years I figured it was smart to get an OEM colour that was pretty common for all of those sensible reasons one can think of..
    • I absolutely love having clean wheels and also totally love cleaning them. Its not as important to me to have a clean car exterior as it is to have clean wheels. So I bought a kit. I generally use different products for my wheels than anything else, so I thought I'd buy a proper kit and bucket to keep it all in. I got this one from Waxit. I also got the CQuartz wheel and plastic ceramic along with a bunch more application micro fibre pads as CQuartz never provide enough.  The kit was good, but as usual the big, long spongey thing didn't fit between my spokes, so I needed to use a detailing brush and a larger brush that I already owned (been doing this forever, the spokes on these wheels are frustrating.) I did a full clean with the wheel cleaner, it has an iron killing product in it, so I found that I could just use the cleaner and nothing else on the wheels. The tyre cleaner and handled brush were awesome. Made cleaning the tyres so easy. Once everything was clean, I decontaminated with isopropyl and applied the ceramic. Two coats. I bought 2 bottles as I have a lot of wheels to do, half of one bottle did two coats on these. The X5 has 20's so I reckon probably 3/4 on that. Then, for possibly the best part, the wheel cleaning kit comes with a tyre black applicator. But, this is possibly the greatest sponge of all time - its a great size, quite stiff and HAS A COVER! When you finish applying the black, you just put the cover back on! This is revolutionary, I normally have to try and find safe places to put my tyre black applicators as they are covered in silicone and tyre crap. Or, you use something which just falls apart. This applicator is the bee's knee's. Get one. It's worth it. The tyre black is also like a cream, its very thick but goes on really thin, its very easy to use with the applicator. Ayway, after a big clean, decontam, ceramic coat and tyre black the wheels went back on and they look awesome.   Thought I'd share.
    • Haha. Good work. I feel some of your pain because I spent a bunch of time under my car over the period too. Probably nowhere near as much as you did. My happiness is similarly improved by obtaining a desired result though. Those side skirts are.....hecking. Very unfriendly for street and hoist. Sounds to me like you've made a cart that needs to be driven up only planks/blocks at a 2 post hoist, rather than trying to get it up onto a 4 poster. It's very pretty, by the way. Somewhat reminiscent of Marty's squid ink on SuperGramps - at least in the photos.
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
