Heya all,
I've been toying with the idea of getting a stock rear bar (R32), and having the 'SKYLINE' part of it light up at night...
I went to a custom bodykit manufacturer, and he reckons I could use a belt sander to shave the letters off from the inside, because of the indentation on the letters. Alternatively, if that doesn't work, then I might have to sit down with a die grinder and do it all VERY carefully! If i slip up just once, it will ruin the whole thing ;)
Then I would need to put a perspex sheet behind it, and seal it so its watertight. Then just run a couple of globes from the rear lights to it, so it comes on with the lights. If I angle the lights right, it should light up the entire sheet of perspex, if you all know how perspex reacts to light :D
Kind of hard to explain what I'm getting at, but if you use your imagination, I think it will be a worthwhile mod - would also give all of these used R32 rear bars a new lease on life! :D Can put all sorts of colours through it, or even use a multi-coloured neon with colour selector in the cabin.
It's bound to set one 32 apart from another, and that's what it's all about, in an age dominated by BN kits and Vertex bars. B)
I've got a few other crazy ideas on mucking around with 32s, if anyone cares to hear 'em...
Adrian.
https://www.sau.com.au/forums/topic/91513-custom-r32-skyline-light-up-trick/
Heya all,
I went to a custom bodykit manufacturer, and he reckons I could use a belt sander to shave the letters off from the inside, because of the indentation on the letters. Alternatively, if that doesn't work, then I might have to sit down with a die grinder and do it all VERY carefully! If i slip up just once, it will ruin the whole thing  :)
Then I would need to put a perspex sheet behind it, and seal it so its watertight. Then just run a couple of globes from the rear lights to it, so it comes on with the lights. If I angle the lights right, it should light up the entire sheet of perspex, if you all know how perspex reacts to light  :P
Kind of hard to explain what I'm getting at, but if you use your imagination, I think it will be a worthwhile mod - would also give all of these used R32 rear bars a new lease on life!  :) Can put all sorts of colours through it, or even use a multi-coloured neon with colour selector in the cabin.
Adrian.
Sounds good.
Post up some pics if u manage to get it done.....
you mean like this?
welcome to 2002 :P
The part that lights up is a factory option that came on R32's from certain dealers in japan. It lights up slightly blue due to the EL sheet it uses. You can pull the EL sheet out (as it usually craps itself after a few years) and replace it with surface mount style LED's.
yeah my 33's got that. lights up a bluey green color..... like so.....
and yes the cops will harass you about it, coz they did with me and thats the reason why the wire is now disconnected so it doesnt light up anymore. ;)
yeh i have this on my 32 but it doesnt light up as its not connected wouldnt mind gettin it to show white light
i couldnt see anyway of f*kin around with the lighting tho, but in the day looks good as you can acutally read it
Edited by RB-Sam
Dammit! I thought I had thought up of something original! Oh well, I've got a few other crazy ideas for modding the 32 unlike anyone else's I've ever seen. Might have to keep them secret until I do it all... B)
Planning on pretty much doing a full-custom bodykit and interior, but I won't spoil the broth and spill the beans at the minute. You'll all just have to wait! :)
On what grounds did they harrass you about it for??  Sounds like a load of crap to me, i can't see anything that they could possibly pick on it for...
yeah I've never had any issues with mine, as when I'm driving normally it dosen't do the knight rider thing, it just acts like a regular brake repeater and all 7 characters light up. Pretty much like a high mount brake light.
Any light on the back of your car needs to be red, or it can be considered defective. The same goes for the sides which have to be orange and the front has to be white.
That said I have seen a cop defect a car for having Altezza style rear lights. The guy pleaded with the cop that there was nothing wrong with it. The cop said and I quote "I'm a police officer and I say its defective so its defective."
So really they can get you anyway they want. I guess its easier to get it cleared than take it to court, which means cops can defect just about anything thats not standard.
altezza lights are almost always illegal. thats why they say "for off road use only" when you buy them.
factory mazda 1's are obviosuly going to be fine
Ok. I was told different. Like I said I had always thought that as long as you had red on back etc. you were fine. Especially since Altezza lights do exactly the same thing as normal lights.
altezza lights are defective if they don't have red reflectors on them. Most ricer opt not to get reflectors as they're not JDM tyte enough with em on.
I guess my rear "SKYLINE" lights up red with the brakes, so that's why I don't get hassled about it.
yeah and mine lights up like a bluey green color like in the pic.
the reason was, coz its an "aftermarket lighting feature" pretty much using the same grounds to harrass you the same way as if you had underbody neons. thats the reason i got, and yes i think its a load of shit, and am thinking i should just hook it back up again and not care, coz i didnt get fined, just asked "nicely" to have it disconnected.
and dezz yeah i will say that if i get asked about it again when i hook it back up :(:)
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
