Bought this fella thinkin it was normal speaker output. It requires external amps even though it says 4 x 45..unless I'm missing something, rca's go into amps.
Anyway, this suckers got everything...aussie frequencies. Brand new!!!
$265.. first in first served.
Features:
DVD/ VCD / SVCD / CD/ HDCD/ MP3/ WMA/ JPEG/ CD-R/ CD-RW/ DVD+RW/ DVD-RW Compatible
FM/AM Receiver
Anti-Shock Housing, Advanced ESP, Last Memory Function
Standard size, can be used as In Dash Size (with trim plate)
4.1 channel Audio system
Digital Audio Output
Extra Infrared Remote Sensor
Dolby Pro-Logic / DTS Ready
Pure Blue /Green Led Indicator
Main Characteristics:
The unit have standard One Din IN-DASH dimension.
With FM/AM tuner, FM Frequency range: 87.5~108MHz, AM Frequency range: 522~1602KHz.
LMF (Last memory function): When power is suddenly down, then power on again , the player will play from last position it played , not from the beginning of disc.
Electronic anti-Shock function inside. The unit is provided to support disc track buffer time (CD/VCD 12sec, DVD 3~6sec, MP3 110sec).
Dolby AC-3 and DTS audio decoders inside.
Composite funtion on front.
The unit is also support CD-R upgrade.
4CH analog audio output, 2CH analog audio input.
2 way video output, can connect two monitor device at the same time
A/V input jack on front panel.
FM can save 40 bands, AM can save 30 bands.
VFD display on panel.
Accessories:
Full function remote controller.
Power Connector
User Manual
Audio/Video connecting cable
Mounting Bracket
Trim Ring
Mounting Grommet
Rear Strap
Keys
Screws
[email protected]
