Been meaning to post this up for a few weeks now.
Checked my interior fuse box (the one under the dash) just to compare it to what it says in the manual (a JPNZ ENTERPRISES reconstruction of the original japanese version) and noticed a few irregularities.
The diagram (black background with all the John Madden playmaking arrows ;)) shows where my fuses are located.
Yellow background attachment is a photo I took of a page in the manual (pages are actually white but auto-balance made it go all Indiana Jones-like).
So yeh, basically I think I'm missing one of the 20A Blower Motor fuses, I seem to have 2 fuses for nothing and a 20A fuse for the airbag (which my car doesn't have) which should be a 10A fuse anyway??
What's going on? Is my manual wrong?
Also, how do I go about buying replacement fuses? I had a look last time I was at supercheap but noticed there were different types (some additional rating -not Amperage- which differed) of the same Amperage fuses and didn't know what ones to buy.
thanks!
https://www.sau.com.au/forums/topic/91573-interior-fuse-box-problem/
its all correct, trust me, andthe blower has 2 20A stated because there is 2 blower spots, follow that diagram exactly, yours is stuffed around, go by the diagram you have its right on ..the only thing is that on mine i have a 3 amp on the left hand side on the verticatly at the top for my dash lights.
Thanks Mick,
The vertical fuse spaces on the left, I thought they were just for holding spares? You said you have a 3A fuse there for your dash lights though?
So I need to remove the fuses in the sixth row down, both left and right side, because they should be empty yeh?
And I could remove the 20A from the airbag fuse spot because my car doesn't have airbags, and put it in the first blower motor spot that has nothing?
is there any reason why you'd have a fuse for the airbag spot when there is no airbag?? lol Dont know what the previous owner did!!
is there anytime you would use the empty fuses spots (sixth row), like for aftermarket accessories or something they may have had?
Thanks again.
