Hi Guys,
I have a toyota 1FZ-FE (4.5L Landcruiser petrol engine) fitted with a GT42 in my old Toyota Crown. Currently the motor is 100% stock and I'm pushing 19psi into it. I'm trying to source some head studs for it so I can crunch the head down a bit harder before I squash too much more into it. Considering how easy it is to get bits for the RB series motors I'm wondering if the RB25 or 26 head studs would be suitable.
What I'm after is the length, diameter and thread on the head bolts for the RB25 and 26 (I have read that the RB26 ones are bigger?)
Thanks in advance.
Sean
Adelaide
https://www.sau.com.au/forums/topic/91583-rb25rb26-head-bolt-size/
RB25 had bolts are 11mm
RB26 head bolts are 12mm
You would be much better off (cheaper and larger range) going for 12.5 mm (1/2") Chevy head studs. ARP have a full range of sizes.
;) cheers:)
Cheers mate.
With the bolt sizes you've listed it's not an option anyway (1FZ ones are 10mm), but the Chev bolt idea is a good one. Cheap and plentiful.
All I need to do is work out how to re-drill and tap the head bolt holes in the block whilst the motor is still in the car (I'm sure it can be done). Providing none of the holes open into any of the oil galleries it should be fine. (my old 5M had one or two head bolt holes like that).
Thanks again.
Sean
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
