For an R32 - would you take a stock GT-R, or a GTS-t that had enough performance and styling bits thrown at it to make up the price difference? Let's say you were just buying them as is, with no intention of modifying the GTS-t any more, or the GT-R at all.
That's about $10000 worth of mods . . . what's your opinion?
J
https://www.sau.com.au/forums/topic/9159-which-would-you-rather-have/
  • Replies 53
with the money you spent on a gtr u could get a good gts-t and do a shit load of mods and get it going heaps better then a gtr, if you do everything properly.
that is if u didnt do any mods to the gtr.
dare to be different i say!
This is something im thinking about every day.
Currently i have a 32 GTST that is modded in every way, nothing is realy stock except my seats. Has 235rwkw, full suspension upgrade, new rotors/pads, body kit, wheels etc. Probably spent, well i better not add that up ill scare myself. It goes hard, stops and turns and is great fun to drive. But not good enough yet.
Im thinking either RB25, bigger turbo etc and get about 270rwkw with huge brakes and a totally stripped r32 to keep the weight down OR get a GTR and do some mild mods with new sus brakes to make a killer street/thrash car. A gtr will be quicker on the street you would think due to traction and would be a nicer car to drive daily. the only thing i dont like is when you open the bonnet and there is crap eveywhere, that and if something breaks it will cost a lot more money.
Depends on which you mean. I would only consider the "33" types. For some odd reason I've taken to the 33 over the 32/34 besides the fact it has the most boring interior and arguably the most staid exterior.
Eventually I'll have a 33 GT-R but it seems like an odd upgrade over the 33 GTS-t. It'll be faster in every respect but it won't be as 'fun' to drive, it'll use even more fuel (!!!) and it'll set new standards in extortionate repair and performance bills.
I don't contemplate looking at the same interior again...
T.
i would definately go the GTST with 10k in mods.... drop an Rb25det in it... bigger turbo... fmic... ECU... boost... suspension brakes and tyres... if theres anything left over then work on the exterior
  • 1 year later...
After owning a stock GTR and a fully worked GTS-t, I choose the GTR hands down.
It really is no comparison. The GTR makes such a lot of torque so easily, and is a much nicer car to drive... ATTESA is a godsend too... No point in making 300rwkw if you struggle to put it down and get stomped by stock GTRs off the line...
Given your wording, it could be suggested that the lower-spec has been modded in every way - so every department is up to GTR quality (and god knows how much money that would take?! - a HELL of a lot more than $10k even in canadian $$). Then you essentially have a GTST and GTR with the same performance and luxuries. If both were essentially equal, why would you take the GTST?? (less prestige, less resale value, and so on)
Would I take a GTR over a GTST with $10k thrown at it? Of course.
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
