Guest a31rb25
just bought a steering bush and solid aliminium cradle bushes from Zenith Tuning (cheers Brad!) which will be installed in the next few days
was wondering if anybody would be interested in a brief do this/don't do this for future reference. pics will be included. will probably do it in a word-doco format as i don't know how to add mass pics to a post
any takers?
https://www.sau.com.au/forums/topic/91603-cradle-bushes/
Guest a31rb25
Daveo, what's so bad about them, i understand that they induce oversteer, but is it that bad that it effects daily commuting? as for adding to the stiffness of the ride, i'm not too concerned with that, the car is already awful on anything that has a few bumps, lol
regardless of how they effect the car, i'll post here and on Cefiroz.com a report on them and an article about installing them. hopefully with pics too
https://www.sau.com.au/forums/topic/91603-cradle-bushes/#findComment-1652609
  • 2 months later...
Yeah I got some alluminium inserts, what I am thinking about doing is keeping the bottom ones in and repacing the top part for some smaller cut pinapples. just finding with the LSD too much noise when it locks around slow tight corners such as three point turns. basically metal on metal no dampening. see how you go I am hoping to get mine in, in the next couple of months. Its been put off for a while and just got put off longer with a little acco today. (see pics and post)
https://www.sau.com.au/forums/topic/91603-cradle-bushes/#findComment-1864680
LoL one dont, dont use soild aluminium ones!  They are harsh, fun when you want it, but a pain the rest of the time.
Normal driving they are all good, yeh alloy ones make it harder than pinapples but lets face it the whole idea of them is to stop the harsher AXLE TRAMP and alow the wheels to spin with no issues.
GET EM INTO YA!!!!!!
https://www.sau.com.au/forums/topic/91603-cradle-bushes/#findComment-1869269
Some people say the best of both worlds are PU on top and solid on the bottom.
Means it ends up tight but the NVH isn't transmitted to the car as much. I got my PU pineapples for $40 I think. Not that much in order to preserve some semblence of aural quality.
Good on ya for the article. If you want to just get the pics and send them to me seperately and just write the article in a PM or something I'll be happy to format it and put it up on cefiroz.. Good on ya!
https://www.sau.com.au/forums/topic/91603-cradle-bushes/#findComment-1879611
My understanding is that there are 4 types of subframe bushes.
The first type are the actual bushes in the subframe itself which are pressed in. See attachment below.
When these factory items get old the subframe has movement, then people fit the alloy type of spacer bush as is being discussed here, which is the second type of bush.
Then there are solid ally bushes which are installed to crush the std fatory bushes, seen here : http://www.skylinesaustralia.com/forums/in...246&hl=subframe
Then there are the pinapple urethane type which are used to tilt the subframe for drift or traction seen as posted here : http://www.whiteline.com.au/docs/instructs/203a_KCA349.pdf
I reckon im going to fit the first type i talked about (the actual bush replacement) which is a hard job, but will be worth it, and then fit the urethane type to angle the subframe for traction.
I just see the alloy type as a quick replacement for fitting the actual subframe mounts.
NSB_66_Nissan_Silvia___Skyline_Subframe_Mounts_1_.pdf
https://www.sau.com.au/forums/topic/91603-cradle-bushes/#findComment-1905359
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
