Hey all i have a ps2 with 1 controller and all necessary cables for sale $100 also an Astro 7" brand new headrest monitor $330 i bought it about 2 weeks ago and didnt get a chance to put it in as i need the money to fix a windscreen that some tool thought it would be funny to break. Im in canberra but willing to post anywhere at buyers expense. I can get pics for those interested upon request
https://www.sau.com.au/forums/topic/91618-ps2-and-7-headrest-monitor/
Hey all the normal ps2 is gone, sorry but im debating wether i should keep my slimline ps2. If the right offer comes along id be willing to part with it. had plans to put it in the car but am getting increasingly lazy. $180ono still have the box they are $250ish new.
cheers semo, im in canberra btw
Yes sir indeed i do, i can give u all the specs now, if u give me a few hours i can jump to a mates house and take some pictures.
Features:
Ultra Slim Design
7" diagonal Wide screen (16:9) TFT LCD colour display
Full function on screen display
Built in IR transmittor for wireless headphone
Headrest Mounting Bracket
Full Function OSD remote
Auto switching NTC or Pal System
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
    • The ECU does care - it runs the engine as two banks of 3 wrt O2 trimming. So you have to give it the right one. Um....look at the engine bay pictures in the GTR manual? I think you can make them out there. I think the physical wiring diagram might also help.... Actually, I just looked at the engine bay wiring diag. It clear shows the shapes of the connectors. I'd say that R means rear. According to the rest of that diagram, pin 2 of the R one turns up at terminal 55 of the ECU. Which is.....the rear one.
