Hi,
I've done a search on the topic, but as my car isn't really stock ad i don't really know much about the difference in plugs (cool, hot, the gaps etc) so i thought i'd post asking what plugs i should go with for my 94 R33 GTS25t.
My current mods stand at:
ARC FMIC
Injectors
Fuel pump
HKS GT3040 Turbo
Exhaust Manifold
Full 3" exhaust
Oil Catch Can
OS Giken Twin Plate Clutch
HKS FCONV
HKS PFC-FCON
HKS VPC
Greddy Profec B Boost Controller
I'm looking at running 18-25psi once i find someone to tune my car in Melbourne (and depending what is safe), so i'm not sure what spark plugs i should get. I'm not too worried about the price, I don't really want to go ordering HKS plugs from Japan!
Any ideas on what i should get?
Also what engine oil? and should i use one of those Oil Drain additives when i change it?
Thanks
Andrew
Plugs - I'd run at least a 7 heat range (I do) & gap them to 0.8-0.9mm. If you had an upgraded ignition system then it'd be far better to keep the gap @1.0-1.1mm.
The NGK "Iriway" 7's are a good choice. "Iriways" are one of NGK's Iridium high heat range, special order in most cases (~$30ea) If that's too expensive then I'd go for Platinum in a 7 heat range (~$16-18ea).
If you don't mind changing plugs regularly then just use BCP7ES, if they do a 7 in the BCP range?
Most of the HKS, Trust type plugs are just the same as the NGK Iriways (but closer to $40-45ea!).
Edit:
Oils - Motul (300V) or Redline are both excellent oils.
GiJOr33,
I agree with whatisname, go for either platinum or Iridium plugs from NGK, I gap mine down to 0.7mm because otherwise you'll get breakdown at high boost.
The redline stuff is very good, but for the price I'd still use Mobil 1 unless your racing the car. Change oil and filter more regularly if your treating the car harshly.
See'ya:burnout:
Cool... thanks for the tips guys. I think i'll go Mobil 1 oil, and the Iriways from NGK.
What is the difference in heat range? what does it mean? And how come you picked 8s over 7s Merli? and is 8 hotter or colder than 7?
thanks again
Andrew
8's are cooler
for big boost, 7 and 8 are both good, but with aftermarket managent, and bigger injectors I'd lean towards 8
coppers, Iriways, platinum all perform the same, but coppers dont last as long. I'd go the coppers anyhow as replacing spark plugs is better than cleaning (as you would with the more expensive at certain intervals)
Dont know if coppers come in 8's but a good choice in 7's is NGK BCPR7E. If there is a BCPR8E, then go for that...
my 2 cents
Zahos
I can't remember the exact rule of thumb? But it's something like for every 75hp increase go one heat range cooler than standard.
1 - hot
10- cold
A stock R33 RB25DET is ~250hp & runs a 5 heat range plug
325hp - 6's
400 - 7's
475 - 8's
& so on...
Going too cold for your engine requirements can cause fouling @ idle & cold starts. If the plug tip temp is too low it'll foul very easily.
I figure my engine is somewhere ~400+hp hence I use 7's.
EDIT: - Just checked the US NGK site. They recommend 1 heat range cooler for every 75-100hp increase over stock.
Pretty much everything in this thread is correct...
Glad to see the performance-oriented guys helping each other out on this forum :uh-huh:
benm: 192rwkw from a stock turbo is excellent! well done, time for a turbo upgrade to bump yourself into the 200s! :rolleyes:
With 18-25psi of boost I hope you have some forged internals, I'm pretty sure the factory pistons will not like this boost. The GT30 should start producing real power arond 18-22psi, so it should easily get some big power.
See'ya:burnout:
My car is running pretty well - but will reducing the plug gap to 0.8mm give any improvements? I'd say they are currently gapped to around 1.05mm but i haven't pulled them out to check.
Actually, how do i even get to the spark plugs? Do i have to remove anything? Are they just between the injectors there or do i have to remove the top case?
At stock boost then the 1mm gap is ok, but as you increase the boost then the gap needs to be decreased, unless you run a CDI.
To get to the spark-plug you will need to remove the cover off the top of the engine, which usually means taking the intake pipe to the plenum off, then with an allan key you take the coil-packs off and the injectors are sitting down in the block. You will need a long socket to remove the plugs.
You can easily regap the plugs with a set of feeler gauges.
See'ya:burnout:
so it doesn't matter if i run copper/platinum/iridium, as long as it's a 7 plug?
what's a CDI worth these days leewah?
I do have a shit cold start at the moment as the car needs a tune (got HKS gear... no one in melbourne to tune it!). So i'll get new plugs to go in once it's tuned
I think that the HKS plugs are a waste of good money, they are good for one day of circuit racing then after that I would throw them away. The number of times my tuner has pulled out f#cked plugs and they are the expensive HKS ones.
Predator666,
I think that is Murphy's law, you mustn't work on your car much as it doesn't get to 35 often in Melbourne.
See'ya :burnout:
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
