Originally posted by Merli
benm: 192rwkw from a stock turbo is excellent! well done, time for a turbo upgrade to bump yourself into the 200s! :D
I won't need a bigger turbo to get to 200rwkw don't you worry about that
hmm, coincidence, i have just spent half the night pulling apart half my engine o check, clean and re-gap the plugs. On the r34 standard gap is 1.0 mm. The current plugs in there are NGK-R PFR6G - 11. Does anyone know which plug this is?
They looked like they were put in somewhere in the last 2-3 months [just before i bought the car] but i dont know if these are just copper ones or not? Or if they are the right heat rating [is it the 6 or 11 :confused: Any help on this would be good.
I have re-gapped them to approx 0.8 > 0.85mm as the car seems to run a bit rich [stock ecu / car / etc]. I am not sure if the 34 should be the same as r33 spark plugs either. Damn finding info on the 34 is a nightmare atm
Thanks guys...:( [sorry about the thesis]
NGK-R PFR6G - 11
That is NGK's part number code (as you know)... This is how you interpret it:
NGK - Manufacturer
PFR - Platinum Spark Plug
6G - Heat Range 6
11 - 1.1mm Gap.
I use to think that the R34 & R33 RB25DET's used the same heat range plug standard (6's) It turns out that the R33 engine has a 5 heat range standard & R34 a 6!
Both are a 1.0-1.1mm gap factory.
you are still wasting your money, trust me! Just go and spend $3 per plug on coppers. They are much better for the line, as platimuns dont do jack for performance (in fact, in some cases they were worse), and you will need to change them before you know it (b/c of line running so rich!!!
Search around these forums on this. It has been brought up many times, and you can find heaps on good info on this! Always do that before asking a question, as many subjects raised have been covered many times....
I was lucky coz my partner was selling a brand new Autronic CDI for $750 which was cool to match my Autronic ECU. Usually I think the CDI is about the $900 mark retail and then you need it installed. The spark is HUGE!!!! I recommend a CDI to anyone who wants to run high levels of boost.
I'm now leaning towards the copper plugs coz from what I've been told and researched, copper is a more conductive material than platinum or iridium. The only problem is that you have to change your plugs more often.
What kind of tuning do you need? Give us a call at the factory on 9512 7591 and ask to speak to Gerald or Nigel. They should be able to either help you with the tuning or point you in the right direction.
Originally posted by GiJOr33
so it doesn't matter if i run copper/platinum/iridium, as long as it's a 7 plug?
what's a CDI worth these days leewah?
I do have a shit cold start at the moment as the car needs a tune (got HKS gear... no one in melbourne to tune it!). So i'll get new plugs to go in once it's tuned
You guys did my Twin Plate OS Giken Clutch... remember, i've got all the HKS computer gear (PFC-FCON, FCONV, VPC).
I'm still looking for the software, which i think i'm gonna be hard pressed to find.
How often should you change the copper plugs and which model number? BCPR7E, is that the copper NGK's with a heat range of 7? or should i get 6... cos the car isn't really given a bootfull all the time, it's a daily driver. So if i get a 7 i don't want the plugs to foul up just from putting around (would a good full noise run clean them or do you have to do a couple of hard runs?)
Andrew
Ahh yes, I remember being told bout all the gear in your car. Good luck finding a tuner in Melb. Maybe if you asked BD4s, they could help you in some way. They are the official distributor of HKS in Aust.
Because I've had spark issues recently before the CDI, I went through about 3 sets in 4 months coz of fouling the plugs. Fouling copper plugs was a much cheaper option than platinums. I reckon most people around here would use either the 6 or 7. If your not going to be driving hard that often, I would say the 6 would be a better option. Also the 6 would give a better cold start.
Cleaning the plugs is simply a case of hammering the car stupid for bout 5 mins. That should clean all the charred stuff off. If that fails, WD40 and sandpaper does wonders. On the other hand, $3 for coppers plugs may save you all the time and effort :D
Andrew
yeah i've spoken to BD4's... they basically just said "nup, we are the only ones that do HKS tuning". I've been given a name of a guy who does performance car tuning around SE Asia, so hopefully he has all the software. The hard thing will be catching him when he's in Australia!
I think the $3 option is better than the effort of cleaning them!!! Probably takes about about 15-30min to clean them all properly, i'd rather chuck in some brand newies and save the hassle!
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
