what car, what mods, do you get black smoke? do you see any fuel coming out? what happens when you floor it? sounds like dead 02 sensor without knowing any more information
Hey guys, yeah its really wierd..
mods are 3" exhaust, 3" dump pipe and pod filter..
stock everything else... i took it in to get it looked at they tested it..
the O2 sensor was going nuts, but then he checked another R33 and wa doing the same thing.. i think they are going to change the spark plugs and dyno run it... see whats going on.
- Andrew
is there anyway to tell if the fuel reg is screwed without having to anoy a mechanic ?? any simple checks ?
could be a faulty fuel reg... but even then... i still had 200km's to a tank whe mine died
slap a pressure gauge on and go for a drive.
you'll soon workout if its working.
although, all you do is rev the car while its sitting there and if it belches some nice fuel cloud then its pretty certain.
Mine filled a workshop with fuel vapour/cloud after a good 5 revs. IT was a big cloud :)
I checked the pressure like 3 years ago when i shat one... the fuel cloud i knew from, but checked it anyhow as i was bored.
I cant remember what its meant to be
Are you saying it is using a lot of fuel by reading the gauge?
Cause the fuel level sender can come off its bracket pretty easy. I know mine has done it in the past.
Might be worth checking. Sometimes it is the simple things.
Adam
The TV show Top Gear reported getting 4 mpg in a Ford GT40 doing burnouts etc. on a race track. That is about 60L/100kms full throttle on a race track. If you can beat that whilst driving off boost, it can only mean a fuel leak somewhere. I cannot imagine fuel consumption THAT high just from poor tuning.
I was thinking huge injectors with PFC in japan and they replaced the
PFC with a stock computer to sell it but even then it would run like shit and not use that much fuel.
I would say you have a leaky injector/s, a hole in the pressurised supply side of the fuel system. or a V8 holden lives in your petrol tank :rolleyes:
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
