Lets put some facts down....
If the fuel were burning then you would have a black rear bar (like me) so if you arent spewing black smoke from the tail then it must be leaking.
Where could it be leaking:
* Hole in tank
* Hole in a pressured line
* Over flow not connected back to tank
* Leaking injectors
You should be able to smell fuel tho on all of these situations....
Well, here's a thought.
I drank about 60 litres of fuel racing at Winton.
I did 24 timed laps, total of about 50 klms.
let's call it 1 litre per kilometer. BUT I was at WOT most of the time.
Maybe the drive was a little spirited?
hey dude check ur fuel purge tank n make sure all the hoses n shit aint blocked n stuff. my mate had a 180 and it popped flames like crazy idled rought n the cause was all the vacume lines were f**ked and pluged (some were also blocked by screws) in everywhere. he used 1/4 of a tank going about 25 km's... just a thought tho
Edited by kamakazi
Hey Dude Similar Thing Happen To Me But it werent that extreme
when i first got me car was getting round 200ks full tank
was getting strong feul smell in car but no smell from outside
found out the mechanic accidentally busted my feul breather hose when he was modding the feul filler valve
when filling up check the little rubber pipe next to the big feul tank filler pipe
good luck
Skyline-man, where are you...
I'v heard that you can chew soap and use it to plug up fuel tank punctures. Of course, doing that anywhere but the nullabor plain is, well, distateful...
find where the fuel is leaking from. This includes coming out the fuel cap. Happened to me all the time in my old magna (though your cap should be better).
I wanna know...
lol
as above - hole in fuel tank, or your gauge is seriously screwed.
If you were blowing out enough fuel to consume 70L/100 in a reasonably stock gts-t, then im sure you would notice it out the back. your rear window would be tinted ;)
If the gauge is screwed then it still wouldnt explain why he has to fill his tank UP to full!!
Or havent you looked into this possibility?? Not u,him.
You have 10,000cc injectors.
Edited by Trust33
10,000cc injectors. Too easy. :lol:
El Bee
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
