Hi Guys,
I have some mags for sale, aswell as some clutches. PM me if your interested.
The first lot of mags are 16x6.5 with a 4 stud pattern for Silvias etc. There are only 2, they come with the rubber which is 205/50/16's with 75% tread.
Price is $120 each.
https://www.sau.com.au/forums/topic/9171-fs-mag-and-clutches-perth-only/
Ok, the clutches I have are.
1 Nismo 4 puck clutch for a Skyline $500.
2 Twin-plate clutches for 300ZX $1000.
I am trying to get some twin-plates for Skylines but they sell really quick so it's much harder to find.
See'ya:burnout:
MrMayhem,
There are plenty of perfomance 300's around, many with over 300rwhp, so for them a twin-plate would be ideal. A few drag 300's are also being made, pulling 9sec.
See'ya:burnout:
See'ya:burnout:
In your opinion gtstVSPEC would the 4 puck clutch be better that a 2500lbs multi button brass clutch? Also is it nice and easy to push the clutch in? I can't stand being on the freeway in peak hour with a friggin hard clutch to push in...
25GTT,
The less pucks the clutch has the stiffer the uptake, but that doesn't mean that the clutch will be heavy, that is more dependant on the way they spring the clutch, like they do with the heavy duty rebuilds.
The Nismo 4 puck should be stronger than the 2500lb clutch and it is cheap to rebuild, only $350.
PVA,
Remind me what you were after again. I can get lots of 15's but 17's are getting scarce, I have some 17's as drag tyres.
See'ya :burnout:
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
