CeffyNSW Posted October 19, 2005 Share Posted October 19, 2005 Hi Guys Can I use R33 1/2 shafts or do I have to stick to R32? Can anybody please advise Thanks Link to comment https://www.sau.com.au/forums/topic/91723-replacing-r180-diff-with-r200-on-ceffy/ Share on other sites More sharing options...
replicate Posted October 20, 2005 Share Posted October 20, 2005 I used an S13 r200 diff and axels. By half shafts do you mean the part that sticks out of the diff housing with either the 6 or 5 bolt flange? Link to comment https://www.sau.com.au/forums/topic/91723-replacing-r180-diff-with-r200-on-ceffy/#findComment-1654424 Share on other sites More sharing options...
CeffyNSW Posted October 20, 2005 Author Share Posted October 20, 2005 Half shafts are the shafts that go from the diff to the hubs. Assume an R33 R200 diff will fit. Regards Link to comment https://www.sau.com.au/forums/topic/91723-replacing-r180-diff-with-r200-on-ceffy/#findComment-1655711 Share on other sites More sharing options...
too_much_boost Posted October 20, 2005 Share Posted October 20, 2005 You just need to make sure they have the same bolt pattern. They will be either 5 or 6 bolt. My cef is 6 bolt but i think 33's are 5 bolt Link to comment https://www.sau.com.au/forums/topic/91723-replacing-r180-diff-with-r200-on-ceffy/#findComment-1656567 Share on other sites More sharing options...
CeffyNSW Posted October 21, 2005 Author Share Posted October 21, 2005 Thanks for the comment. Both diff and half shafts have 5 bolt patten. Assume hicas will fit around R33 diff, the length of the halfs shafts will be OK and that the splines will match. Regards Link to comment https://www.sau.com.au/forums/topic/91723-replacing-r180-diff-with-r200-on-ceffy/#findComment-1658170 Share on other sites More sharing options...
CeffyNSW Posted October 21, 2005 Author Share Posted October 21, 2005 I was assuming 6 bolt equals R180. Which is standard diff for NA auto??? Link to comment https://www.sau.com.au/forums/topic/91723-replacing-r180-diff-with-r200-on-ceffy/#findComment-1658175 Share on other sites More sharing options...
replicate Posted October 25, 2005 Share Posted October 25, 2005 Some R200 are 6 bolt Link to comment https://www.sau.com.au/forums/topic/91723-replacing-r180-diff-with-r200-on-ceffy/#findComment-1667733 Share on other sites More sharing options...
CeffyNSW Posted October 27, 2005 Author Share Posted October 27, 2005 Thanks, Replicate It does get a bit confusing! Didn't end up getting the diff and will leave it for a while while I put the RB25DET in. Regards Link to comment https://www.sau.com.au/forums/topic/91723-replacing-r180-diff-with-r200-on-ceffy/#findComment-1671733 Share on other sites More sharing options...
