  • Replies 181
Posted Images
man! They are bloody bright! trust me, u won't be needing the highbeam much! but R32 are h4's? are u 100% sure? Cause i've got some vague suspicion they arn't. Anyway, If u want bright, 6000k is 2800lm (roughly) 4700/5000 are 3200lm. If i remember 8000k is less than 2800lm. A standard output of a halogen is 1000lm if i remember correctly. A good example would be lookin at the bmw, merc and stuff. Check the links i posted, they have comparison charts.
Cheers!
Checked mine out - I am H4 (bugger!) & would be after 8000K (I guess) but the question I have is are they really bright on low beam as well?
HID's are the low beam, high beam stays as halogen :P
Cool! Set me up for 1 for sure! When do u estimate we'll order it?
Oh yeah, regarding the h4, as bankids said, it's a motor that retracts and extends for high beam and low beam. They are usually called bixenons... that's why h4's usually cost a little bit more. Wherelse for h1,h3 etc, they are single fillaments and they rely on another bulb for the highbeam, like the r33s
http://www.xenonvalot.com/newh4bixenon.html << for reference.
that's the thing confused me alot, coz in everywhere ppl said hid have lower power consumption. normally halogen is 55w but hid is 35w.
but while i installed the hid into my audi a4 burnt my fuse which was 10a, later i put a 15a into the fuse box and everything seems alright now..
my stock headlights were pretty good, but the HID's are excellent. :wub:
so much longer range, and ive got 8000k i think (it was diamond white whatever temperature i bought), looks like daylight! :)
Yo! Diamond White is usually 6000k. When it's quite blueish it's 8000k, then 10000k dark blueish and 12000k is purplish. Daytime white is 4700k to 5300k that's what normal OEM hids come with. But they are the otimal. usually rated at 3200lm. 6000k is 2800lms. But, 2800lm is way more than the standard of about 1000lm. :) hahaha. HID's for a price of $200 is bloody well worth it man.
what is the best possible headlight xenon conversion on the market? i want something very clear , and you can get blue lense also?
h7 or something?
please tell me, i need it for S15
Best possible? You'd be lookin at Hella Ballasts, and philips/osram bulb/globes. Will set u back by a cool 1k. But no one will be able to tell the difference untill u actually show them it's philips and hellas, cause the standard these days are so universal and common that you're looking only at reliability.
Heck, you can buy 5 sets of these for the same price! Nothing gets clearer than HIDs. The bluish tint is not the lense, if u're lookin at lenses, and they tell u it's hid, you're prolly gonna get ripped off cause they are halogen "xenon" convertion where they use relays to pump the wattage to 110W and u get brighter lights. Then they use a cover to cover the bulb to give it the bluish/whitish look. The real xenons are what is being sold on the forum. With a slight bluish tinge, but mostly white, it's 6000k. More bluish is 8000k but a little bit darker, there's a trade off, then it becomes bluish purple 10000k, then purple 12000k.
S15 uses projectors, so look for the projector headblubs, but these days there are universal ones. Rated as D2C. I know there are sellers whom sell the wrong kinda bulb so as to clear their stock. EG: my friend bought projector bulbs for his MR-S. Thou using Philips and Hellas, his car is relatively low, but when i was driving my rav4 back home, i still feel the glare when in front of him. Which got him fined in the end, he had to buy another set of globes for SGD$250 just to be right. LoL. Oh wells.
Come on dude, join this group buy. I'm pretty anxious to get a set here for my r33 so, need to meet the 10 pple quota =E . They are one of the best investment u can make for ur car, esp when driving in dark places, you can see, literally, EVERYTHING.
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
