Hey ppls
Well, some of you lucky people may have recieved parts from me, mainly radiator guides.
Anywhoo. I need a Japlish motto for my parts to engrave, or just provide stickers for fun.
ARC's motto is as follows
The ARC product is wonders asseembiled project. The present comfortable and unknown car life with ARC power.
The name of my parts will be called:
Bass Junky's Bits
Bass Junky give total satisfaction power with excellent design. Happy person to buy with confidence.
That one is lame, but something like that.
So what do you say?
BASS OUT
https://www.sau.com.au/forums/topic/91814-i-need-a-japlish-motto-for-my-parts/
could always go with the classic Skyline motto of "In spartan air we made". Short, succint, and totally irrelevant... exactly what a japlish motto should be.
If you want to know how to make japlish/engrish, you go to:
http://babelfish.altavista.com/
You type in a phrase that makes perfect sense to you, and translate it from english to japanese...
then you copy and paste the result into the translate field again and translate from japanese to english...
Hey presto! instant japlish!
Here's one along similar lines to your original one that i prepared just then for you:
Original Phrase: "This Product is made to the highest standards and you should buy with confidence"
Translated to Japanese: "このプロダクトは高水準になされ、自信をもって買うべきである"
Translated back to English: "You can do this product to high level, you should buy with self-confidence"
Very low level stuff, but have a play around with it, you get some 'interesting' phrases out of good old babelfish :angry:
It reaches always and completes powerful outcomes and accurate .
just put sentences in to a translator, translate to japanese, then translate back..
oops
edit---
what AzzurrA said lol
Edited by sl!m
excuse me shan? I believe it's "we produced with spartan air"... Had to pull you up on the technicallity :angry:.. but what the hell does that actually mean? probably nothing..
In regards to your motto, just mix and match a few things from yahoo auctions.. bass junky's quality produce medieval times....
I occasionally see 'medieval times'...wtf??
Bit of Junkys bass. Give extreme power and the latent characteristic of air current to your car
Comes from
Bass Junkys Bits. Giving extreme power and air flow potential to your car
Bass Junkys bit perform outstanding power increases on your Skylines. The chicks will want to root you because of them.
The bit of Junkys bass increases the remarkable power of your skyline. The chick thinks that we would like to become fixed because of those.
Bass Junkys bit are fully sick and kick arse. These parts rock baby, yeah!
The bit of Junkys bass sufficiently is the anus of the sickness and the kicking. These parts it can obtain the baby, shakes!
and last for tonight
Bass Junkys radiator air guides help the air to flow through your radiator to increase the cooling potential of your car.
Gives:
The air guide of the radiator of Junkys of bass in order your radiator to percolate, helps the air in order to raise the cooling system.
Forget a logo and engraving. Remember thos ecool hologram cards you got in packets of chips as a kid...you knwo the ones that when you chanegd the angle at which you looked at them the picture would move.
Well just get one of those with your car stooopidly sideways on the DECA skidpan...god knows there is enough footage of you tearing it up:)
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
