Hi i was wondering what type of tein coilovers the attached picture is, and how much i could get for them on resale. The picture below is the same model i have however are not actually mine (mine are in better condition). I beleive they are dampening adjustable and height as i have wound it out and noticed a softer ride.
Also what would be some spring/adjustable shock combinations (i.e. whiteline and bilstein adjust.)? which you could recommend for a fairly hard setup which would be good for a stiff setup (little body roll) yet still fairly decent over bumps in the road. (coming from teins, everything seems like its a much bigger bump than it is)
Cheers, David.
https://www.sau.com.au/forums/topic/91815-teins/
Cheers, David.
Hi David, check out the Bilstein/Whiteline Group Buy for your model of Skyline. Body roll is best controlled by the stabiliser bars, that's why the Group Buy kit has good ride, sporty, but not harsh and great handling.
:( Cheers :)
https://www.sau.com.au/forums/topic/91815-teins/#findComment-1657738
How can you tell the difference between HA's and the other ones which are dampening adjustable.?
HA's are damper adjustable. but the ones in your pic look like HR to me.
either way just ask the bloke who is selling them. or do a little research.
https://www.sau.com.au/forums/topic/91815-teins/#findComment-1657905
Hey here are two pics of the coilovers, i was wondering if any of u suspension experts could confirm what type they are.....
About dampening, few wks back i turned the tops of this supsension a little anti clockwise, if i remember correctly, and for two turns or there abouts i thought i could feel a slight difference (marginal but it felt like it was there). This was done using vice grips as there are no "knobs" on the top of the suspension.
Would be great if someone could confirm them....as i want to sell them off and get some normal stiff suspension.
Cheers, David.
https://www.sau.com.au/forums/topic/91815-teins/#findComment-1660545
i am 90% sure they are not HAs. to adjust the dampening you don't need vice grips. there is a little knurled knob on the top with a allen key type hole in the middle. you turn it with your fingers and it clicks as you turn it.
https://www.sau.com.au/forums/topic/91815-teins/#findComment-1662872
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
    • So there is no other way to remove and install the ball joints then to buy the Frenchys kit?
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
