Don't worry too much,
its a pretty normal thing. I've had 2 turbo cars first one being the Mazda 626 Turbo in relatively stock form and it glowed pretty much every time after I drove it frequently at boost and it was factory intercooled. The 2nd one being the R32 which is mildly tuned and the glow was pretty apparent in that too. just not as obvious with the heat shield. you'll only see it glowing straight after you've driven it hard and pop the hood. its a lot more obvious at night after a good twisty run.
if its the exhaust turbine thats glowing than thats pretty normal. they're designed to withstand 100's of degrees of heat. but if its the compressor turbine thats glowing than thats definitely not good a good thing.
just hope it isn't glowing white hot because that can be a bad thing too.
probably just get the afr's checked to make sure it isn't running lean. A dyno tuner can do this in about 15 mins.
Lean makes things hot, and will make a turbo glow red, but it ispretty normal.
If your afr's are fine, and its glowing red, then cool :)
If your afr's are fine, and its glowing red, then cool  :rolleyes:
running rich with ignition timing retarded will also create more heat and in turn cause the turbo to glow red hot.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
