Ideas For Cheap Stealth Car
jmac
 Share
  • Replies 93
Posted Images
i had a nissan urvan with a 5 litre ford on nitrous ....not nice in the wet.....but scared the sh** out of everyone (including me) at the lights....it ended up up near tamworth
When i was younger and sillier i put a 454 chev into a HR holden.
And before that a 250Cube Falcon 6 in a Morris Minor
Put a 350 chev in a 240 Z.....and also a 350 into an XJ6 Jag
Just finished and SR20 in a rodeo
Can't help my self......What i would like to do is put a 13b in a Morris minor...any takers
A vg30 in an EH holden would be nice too
seen a white mk1 escort, with a 378 cube clevo in it.
also, i nearly bought a white hi-ace van a few months ago, with a 302 in it.
on the fantasy front, i think a ovlov 240 with the entire running gear from a gtr would be amusing.
guy aroung my area, name is SOUTHO on these forums i think, has a old cressida with a 1JZ in it. but unlike other modded cressidas this one looks totally stock even with a stock exhaust. now thats a sleeper
Southo has a 2J not a 1J, and the exaust isn't stock, just well thought out :D
I have a 1978 TE Cortina with a 1JZGTE, GT30/40, Haltech and a locker :) .
I got the cooler to fit behind the stock grille and sprayed it black and all piping/siclone clamps. The exhaust is 3 inch turbo back but with a massive rear muffler and sounds just like a 4cyl below 2500rpm.
The brakes are covered up with Ford AU 5 stud persuit rims, all my gauges are concealed (boost gauge in air-con vent temp gauges below dash on brackets).
The only thing that gives it away slightly are the bonnet pins (needed because lots of structual material/bonnet catch taken out to fit cooler) and my 09ONE plates.
There has been manya upset Clubsport/XR8 Owner and maybe a Porsche 993(?) owner as well. Most turbo imports don't take too badly to getting beaten and are pretty interested in the car.
It just so happens it's for sale as well... :)
One of the guys at work has a Mitsu Mirage with 3L V6 Mivec engine in it from a FTO. Engine's mildly worked etc and it goes like a scalded cat !! ( I don't like front wheel drives though ).
Also, there's a guy driving around Sydney in a Jaffa Orange Volvo 240GL wagon that has the drive train from an R33 GTS-T fitted to it. It's not a weapon but has HUGE potential to be one !!
Actually, there are also 2 Volvo wagons running around Syd with 308 stroker's in them ( one light and one dark blue ). I got raced by the light blue one a couple of years ago and it caught me way off gaurd !!!
FTO's engine is a 2.0L V6 Mivec. I considering doing this conversion to a Mirage. 150kw in a 900kg car would make it pretty quick.
2JZ-GTE into a EH Panel Van is a sleeper conversion. There is one in Newcastle.
My buddy has got a Mirage with the 1.6L Mivec motor in it and all the running gear out of the zMirgae's they used to race in the Mirage Cup. It was putting out 148kw on the front wheels, scary torque steer!!!!
Yeah, the Mirage Cyborg-Rs were a decent hot hatch. They were set up to be a Civic Type-R competitor, back in the day....
What about a VR4?
All wheel drive
Turbo
Very plain looking!
Take off the rear spoiler/badges and you got an old lancer like "thing"!
When the engine or driveline go's bang drop in evo replacements.
Heaps of potential! But cheep!
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
