There has been alot of people who have wanted to fit rims with a R33 GTR offset to a GTS-T. Does anyone know if it is possible to remove or shave a little (eg 10mm) off the wheel where it mounts to the hub to change the offset? So in effect bringing the wheel back inside the arch...?
https://www.sau.com.au/forums/topic/9191-modifying-gtr-rims-to-fit-gts-t/
Boost, i think that answers the question. There is no way an inch could be taken off the hub (even half from the wheel and half from the hub sounds like too much), so i guess i'll just have to save up and get those Volk racing rims... :D
What the...
I have R33 GTR rims with semi slicks I use for track work, and they fit perfectly. I have NEVER heard of any offset problems with fitting R33 GTR rims to an R33 GTS-t.
R34 GTR rims however will NOT fit, because they are 18x10" rims and are just way too wide for the front guards.
R33 GTR rims are 17x9" rims.
I'm sorry, but I don't have any photos of my car with the track rims on... I'll have to take some. :(
Bonkers or Red900ss took a photo of my car at a trackday that they posted on here, but I can't find it, and I didn't save it :P
i spoke to a suspension place and he told me that i can lower my car and it wheel camber so they well fit under.Not sure if it will be okay though.Also mine arnt original gtr wheels ,there sparco's that have a offset to suit a gtr ,Not sure on the width they may be wider than stock 33 gtr ,thats why they stick out so bad.
Thanks everyone who has replied to the post.
Thanks Dark, i remember looking at that thread. That R33 has 34 rims on it though, and they do look a bit too wide. Someone surely has a R33 GTS-t with GTR rims with a pic?
I guess i should just try a set on and see how they fit first.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
