SKYLINE R33 GTS25t
POWER: [email protected] of boost [email protected]
<only manage to hit 1.26bar of boost to achieve this time>
60ft: 2.082
ET: 13.563
MPH: 105.27
BP ULTIMATE 98 octane
TYRES: Stock R33 rims with 205/55/r16 Toyo T1R's running 32psi <consistent 2.1-2.2 60fts>
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
ET:12.467
MPH:103 (have run as high as 115 car lost power at 1000ft it was low on fuel)
60':1.898
Tyres: kumho SPT 225/50/16
Nitrous:no
Fuel: VP 103
Nissan:R32 GTS-T rb20 stock long block
timeslip http://www.dragtimes.com/Nissan-Skyline-Timeslip-9513.html
t3/t4 60 trim 18psi
550cc injectors
retuned ecu
z32 maf
FMIC 9x24x2.5
safcII
warblor 255lph pump
full 3" exzost with side pipe video ---->
more things comming this year
Edited by TheLast
  • 3 weeks later...
NISSAN SKYLINE R33 GTS25t Series 2
POWER: Approx 220rwkw
60ft: 2.062
ET: 12.964
MPH: 111.86
Shell V-Power Racing 100 Octane
TYRES: Stock GTR32 rims with 225/50/r16 Toyo T1R's running 25psi <consistent 2.1-2.2 60fts>
  • 4 weeks later...
32 GTR
WSID 28 Mar 07
60' 1.792
ET 12.430
MPH 106.35
K/mh 171.16
NOS:no
BP ultimate, 255/35R18s yoko GP's back, Hankook ventusports, front
Slowest was 23.148 @45.69mph, NA (intercooler hose blew off)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
