Pretty much what i run Mitchee. Annoying somewhat isnt it. You hate the fact your so close to being booted for both cage and a parachute but glad as you get another crack at it :)
What sort of car and how much power?
Edited by ido09s
Yeah, only the one decent run, stuffed the launches on the other 2 runs I got. The car is impossible to get moving in 1st as it just wheel tramps, so launching in 2nd and riding the clutch out a little iv'e found prevents that. The 60' suffers but the mph is more what i'm after than anything. I'm currently making some changes to the car to help get it moving from a stop, and ultimately make it nicer to drive. :)
Its a full weight R34 GTT with about 500rwkw. With ~1/4 tank and me in it, its 1500kg.
  • 4 weeks later...
Thanks mate.
The engine is about 8 years old so I can't remember it InToo much detail but here goes.
Cv performance built in 2006
Stock stroke balanced crank
All forged internals
Mildly ported head with hks step 2 cams
T04z with .70 exhaust hsg
Ran pump fuel on 20 psi it's whole life but recently switched to e85 and 23psi which dropped it from 9.90 to 9.50 then backed up with 9.56.
Running 9" and slicks with a protrans c4.
Rotary Motorsport tunes it and Monro race cars did all the fab work.
There's a 42 page build thread on it dating back to 2006 on the r31skyline forum.
Cheers Joad.
Thanks mate.
Cheers Joad.
  • 4 weeks later...
  • 1 month later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
